566Views2Replies
Author Options:
How would I trigger a solenoid from a timer pulse, either from a 555 or the output of an electronic metronome? Answered
Emphasis on cheap and easy. Small and portable (battery powered) also are big plus. Basically the solenoid- triggered either from a 555 or headphone out of a metronome (which would be easier?) would tap the table (or other object) to the beat. (I'd love to tape this to my drummers head!)
randofo
randofo
11 years ago
Building something using a 555 and transistor would be pretty easy if you know what you are doing. If the metronome works by blinking and LED, you can replace the LED with a low-voltage relay (an AQV210EH) which is basically a type of opto-isolator. Then, when the LED blinks, it would trigger the relay and on the other side of the relay (with a larger power supply) you could power the solenoid.
merrickhard
merrickhard
Answer 9 years ago
Thank you!
