763Views12Replies
Author Options:
How would i clean bearings from roller skates for use in a DIY CNC machine? Answered
What would get off road scum but not the grease inside the bearing
EDIT: HERE IS A PICTURE of a clean one next to a dirty one
steveastrouk
steveastrouk
Best Answer 9 years ago
Clean the whole thing. The shields actually pop off with a pointy knife, and will go back on aftter they are cleaned.
Steve
CopperDropDesigns
CopperDropDesigns
9 years ago
I like to use one of these:
http://www.harborfreight.com/25-liter-ultrasonic-cleaner-95563.html
We use Acetone in ours....in about 15 min it'll be nice and clean.
steveastrouk
steveastrouk
Answer 9 years ago
+1. We use ultrasonics for bearings too.
Steve
CopperDropDesigns
CopperDropDesigns
Answer 9 years ago
Yup...just drop em in and do something else for a while. Then when they are done, just re-oil them....Good as new!
steveastrouk
steveastrouk
Answer 9 years ago
SHIELDED bearings are harder though. Popping off the shields is important.
CopperDropDesigns
CopperDropDesigns
Answer 9 years ago
I'm not sure what kind of bearings roller skates have though, I'm guessing they probably didn't use shielded, but I could be wrong...it has happened once before...lol
CopperDropDesigns
CopperDropDesigns
Answer 9 years ago
Yes, that's very important because the "shield" can trap contaminants inside that even the ultrasonic cleaner can't get out.
oldmanbeefjerky
oldmanbeefjerky
9 years ago
use gasoline. i washed a filthy chain saw engine one day in a bath of gasoline, all the grease just fell off as soon as i poured some gasoline over it. i was astounded!
all grease can be removes with gasoline. well almost all.
lemonie
lemonie
9 years ago
Just wipe them with a cloth / old sock.
L
rickharris
rickharris
Answer 9 years ago
Old sock soaked in Kerosene! My earlier post didn't apply as I didn't read your question very well.
If you find they feel or sound gritty when turned by hand though you may need to clean the old grease a muck out ad re oil or grease. To do that:
Wash in paraffin (kerosene) - this is slightly greasy and an excellent solvent for grease that wont affect the seals.
IF the bearing is dirt sealed you may need to remove them to let the kerosene do it's stuff although soaking for a day or two works as well.
ICBMer
ICBMer
9 years ago
Depending on the grease used with the ball bearing, you could just throw some engine de-greaser (though special acetone is recommended) on it and then reapply the bearing grease.
Met-ol by Oust and Speed Cream by Bones Bearing are meant for roller skate bearings.
I got this info from this site ( http://www.skateboardballbearings.com/ )
I don't know however if this lubrication is appropriate for a cnc machine.
Vyger
Vyger
9 years ago
As far as I know you can't. So the best thing to do is completely clean them with something like paint thinner and then repack the bearings with a good grease. That is how its done with car bearings, and they take a lot more stress.
