527Views8Replies
Author Options:
Hydrogen Oxygen Seperation? Answered
Is there an easy process I can use to separate my hydrogen from oxygen after the fact on my HHO (I don't know what you want to call it but this is easiest) generator.
JoeB459
JoeB459
2 years ago
Using high voltage is the easiest way to separate hydrogen from water I prefer 304 stainless steel instead of 3/16
Kiteman
Kiteman
10 years ago
You don't need to encase the electrodes - that effectively increases the distance between them, increasing the current demand.
All you have to do is catch the rising bubbles.
You can bring the electrodes closer by putting a fine plastic or cloth mesh between them - water will pass through it, but bubbles will not.
jj.inc
jj.inc
Answer 10 years ago
Thanks, I planned on that but I was worried the bubbles would slip out here and there.
Kiteman
Kiteman
Best Answer 10 years ago
After electrolysis, the answer is "No, not for normal humans".
The best and easiest way to separate the two is to collect them separately to start off with - Have an inverted funnel in the water, one over each electrode, and pipe the gas off from the narrow ends of the funnels to individual containers.
jj.inc
jj.inc
Answer 10 years ago
Thanks, I did build one of these like you say, I used pvc to encase each electrode and left the bottom open. They are 3 inches away max and it still has 0 output, unlike my original design that was exactly the same but missing the encasments, any ideas.
NatNoBrains
NatNoBrains
10 years ago
"A common school method of breaking water into H2 and O2 is electrolysis. H2 comes off at the cathode (negative ) pole and O2 comes of at the anode (positive) pole. Unfortunately, chlorine will also come off of the anode from chlorine ions in the system. The water needs to be conductive. Believe it or not, pure water is not a good conductor. Look up A. G. Bell's breakthru on the telephone. He added sulfuric acid to the water.
You could check the amount of time it took to collect a tube of each gas for distilled water (no ozone) (boil it and cool it in a sealed full container as it will pick up CO2 from the air. Then try tap water, water with a spoonful of salt, a saturated salt solution, a tablespoon of vinegar could be added for another jar. Lemon juice might be used. You could get wild and try a aspirin solution. Make up your solutions with the boiled distilled water, so you do not add the variable of the different makeup water salts and CO2. At your age, I would stay away from pool acid and battery acid unless you had the help of a chemist or teacher that is qualified.
James Watts
- Navarre, Florida"
Quoted from http://www.finishing.com/382/71.shtml
NM
rickharris
rickharris
10 years ago
not really - you need to collect in separate containers at the time
