184Views3Replies
I HAVE A DS LITE THAT WILL ONLY CHARGE FOR A FEW SECONDS TO MINS?
I HAVE NO IDEA WHY. SO I NEED TO KNOW WHAT PARTS NEED TO BE REPLACE OR SHOULD I BUY A WHOLE NEW ONE?
9 years ago
You should probably get some more information. Have you tried to figure out if it's the charger, batttery, or the DS yet? You could borrow a charger and battery one at the time and see if that helps.
Answer 9 years ago
I JUST REPLACED THE BATTERY AND CHARGER BUT IT STILL DOING THE SAME THING WHAT SHOULD I DO NOW :((
Answer 9 years ago
Start here -> http://lmgtfy.com/?q=DS+LITE+THAT+WILL+ONLY+CHARGE+FOR+A+FEW+SECONDS
The power of the internet is not having to ask for help because so many have done so before you. Now that we've eliminated the battery and charger(hopefully) you can spend some time googling. Spend a good two or three hours doing this, and you should have learned enough to solve your problem. If you haven't in that amount of time then what you have done is learned a lot of other things for future use.
Good luck with your DS.
-Jim
Also, You should probably bail on the use of caps lock. Most people really don't like it.
