162Views12Replies
Author Options:
I WANT TO JOIN TWO METAL COMPONENT WITHOUT NOT AND BOLT. I WANT TO JOIN THEM BY SOME SOLUTION? Answered
TWO METAL SURFACES ARE ALUMINIUM AND STAINLESS STEEL. I WANI TO JOIN THEM WITHIN 1-2 MIN. OR SOLUTION CAN BE SOLIDIFY BY HEATING.IS THERE AY SOLUTION WHICH SOLIDIFY QUICKLY AFTER HEATING??
iceng
iceng
8 years ago
A shaped explosion will join most differing metals into a gas tight joint !
rickharris
rickharris
Answer 8 years ago
I worked on a British Stainless steel project once where they were making beer barrels From a sheet of Stainless steel by using explosives!
Once the project was proven they were going to go over to hydraulic power. Exciting stuff.
mpilchfamily
mpilchfamily
8 years ago
FYI... When you type in all caps it is perceived as yelling. So there is no need to yell at us. ;)
steveastrouk
steveastrouk
8 years ago
There are also special solders that will work.
steveastrouk
steveastrouk
8 years ago
You don't say how strong the bond needs to be. Wax would "work"
ADITYA1991
ADITYA1991
Answer 8 years ago
I THINK LOCATITE WOULD BE BETTER??
WWC
WWC
8 years ago
Loctite
ADITYA1991
ADITYA1991
Answer 8 years ago
OK I WILL LOOK FOR THAT
rickharris
rickharris
8 years ago
Rivet,
Glue
weld (tricky)
Whip with cord or wire
Fold the edges of the aluminium over the steel.
By the way your likely to get corrosion between the steel and aluminium.
ADITYA1991
ADITYA1991
Answer 8 years ago
THANKS FOR UR SUGGESTION..
