177Views11Replies
Author Options:
I accidently powered my arduino from a wrong pin externally....please help me Answered
My arduino was working and after some time it stopped uploading and it would say
 "arvdude :verification error,first mismatch at byte 0x00000xc != 0x62
arvdude : verification error ; content mismatch"
so i tried troubleshooting but it didnt work so started to think what i did wrong and i remembered that i powered my arduino from 5v pin and ground when i should've powered from vin pin and ground.I think my arduino's fuse is gone but i am no pro at arduino i am quiet new.So can you please tell me how to how change my fuse.do i need to change my  ATmega328 chip or something else.if you think its not the fuse please tell me how to fix it .
Tags:arduino
steveastrouk
steveastrouk
Best Answer 8 years ago
You need a pre-programmed Atmega chip, but probably don't need to change the board - assuming that, when you plug it into your USB port, the board is "identified" properly by your computer.
ms10
ms10
Answer 8 years ago
do you know where to get one
steveastrouk
steveastrouk
Answer 8 years ago
People like Adafruit can supply the single chip,
http://adafruit.com/products/123
or you can be brave and make a PC based programmer and burn your own.....its only very marginally cheaper for an amateur.
ms10
ms10
Answer 8 years ago
thanks
steveastrouk
steveastrouk
8 years ago
What voltage DID you power it with ?
The chip will run happily on 5V , and will probably tolerate 6V, I don't think you'll have bust it, but how soon after your "power supply issue" did it start to go wrong ?? I get the sense that it wasn't immediately.
ms10
ms10
Answer 8 years ago
9v
rickharris
rickharris
Answer 8 years ago
I stand by my original reply.
ms10
ms10
Answer 8 years ago
no it wasnt immediatly
bwrussell
bwrussell
8 years ago
Have yo asked over at Arduino.cc? They are the experts. You could try reloading the bootloader, look for instructions at Arduino.cc. If that doesn't work I would try replacing the chip first since they are only a few bucks.
ms10
ms10
Answer 8 years ago
who do i ask at arduino.cc and can you tell me how to ask a question
ms10
ms10
8 years ago
but the led on the arduino lights up
rickharris
rickharris
8 years ago
You may well have broken it.
