743Views12Replies
Author Options:
I am confused about making iron oxide? Answered
Vinegar + Bleach + Iron = Iron Oxide?
Vinegar + Iron = Iron Oxide?
12 volt energy + Iron = Iron Oxide?
12 volt Energy + Salt + Iron = Iron Oxide?
Hydrogen peroxide + 12 volt Energy + Iron = Iron Oxide?
Can someone clear me out?
   I am trying to make thermite but I have heard that you can make iron oxide using just bleach, however, there have been claims that bleach can actully acumule impurities which makes iron oxide impure which means that thermite will not have the same "performance".
   I found a 12 volt supply in my house and i put a steel inside of a glass, i put the negative and positive but i found no evidences of iron oxide.
   The only thing i accomplish was the glass full of green stuff in it.
Ryan.J.Gaetz
Ryan.J.Gaetz
6 years ago
1 (gloves) (do outdoors)
mix equal parts chlorine bleach and vinegar in large mason jar
2 (gloves)
fill the jar with very fine steel wool and it should start oxidizing, leave jar closed and filled to the top, leave outside preferably. wait a day or two, the the longer the better, and shake it once in a while
*impurities tend to crystallize into larger particles
shake and drain water through coffee filter(s) (one at a time, might make a few filters worth) into another jar. now take out more filters and do it again (shake, filter, into steel wool jar) and repeat as needed.
4
let filters dry out, throw out remaining liquid, and steel wool.
5
when filters dry COMPLETELY scrape off into mortar and grind it moderately.
(you can see my impurities when i grinded)
6
pass through fabric filter in a sealed box.
there you go!
jrh065
jrh065
8 years ago
You might benefit from increasing the surface are of the metal. Try "0000" steel wool in a bucket of water. Oh, and it's going to take a massive amount of steel wool to collect enough iron oxide. You're better off buying it.
jrh065
jrh065
Answer 8 years ago
oh, and that green stuff... If I recall correctly one of the chromium oxides is green and also poisonous. So, I'll bet that was stainless steel. Don't use stainless and get rid of that water.
zaronas
zaronas
8 years ago
try
water+iron+air (O2)= iron oxide
Peter5465
Peter5465
Answer 8 years ago
I am currently doing that, but i don't see any progress.
I am thinking in using hydrogen peroxide or salt or bleach so see which one is faster.
rickharris
rickharris
Answer 8 years ago
Unfortunately you have to add TIME into that equation, a facility not many posters seem to have.
zaronas
zaronas
Answer 8 years ago
true very true
FoolishSage
FoolishSage
8 years ago
Fundamentally Iron oxide is just Iron+oxygen. There are however several things that can speed this reaction up.
Some simple examples:
Heat
Water
Salt water
Electricity
FoolishSage
FoolishSage
Answer 8 years ago
By the way, you will have a harder time making iron oxide from steel than from pure iron. Specially if it is any kind of oxidation resistant steel like Inox.
Peter5465
Peter5465
Answer 8 years ago
The steel i am using doesn't have a oxidation resistance
steveastrouk
steveastrouk
Answer 8 years ago
BTW
inox = stainless steel, for English speakers.
zaronas
zaronas
Answer 8 years ago
thank you for that
Peter5465
Peter5465
Answer 8 years ago
I used a 12 volt power source and i connected the cathode and anode to the energy. the water started to turn into green then yellow, i only see impurities below so i don't think this work.
So, i have to add salt to the "equation" huh?
