96Views1Replies
Author Options:
I am in desperate need of a deflation valve for a queen sheridan air mattress Answered
it is a white valve cap that has two small tabs for grasping. I, unfortunately let a neighbor borrow the mattress and just didnt realize the valve was missing until now........help The mattress is made in China (where else?) and is from Australia
mikeasaurus
mikeasaurus
11 years ago
easy fix: try different resealable threaded bottle caps. the size is usually dictated by the volume of the container, but not always. If you cap is large try a 3L or 4L container. Smaller, try a 500ml or 250ml. complicated fix: You can make a negative mold with quick set putty, gently remove (unscrew), let dry (kiln/oven), then pour molten plastic into the negative to make a positive. trim and modify as needed. get-'er-dun fix: With enough duct tape, anything is possible. boring solution: command neighbour to search for plug tirelessly until found, whip neighbour as necessary. ultimately call the manufacturer and request a new one between tears of defeat. good luck!
