396Views12Replies
I am interest in seldering with aluminum and stainless steel?
I like to learn how to solder stainless steel and aluminum, and where I can order them?
11 years ago
Welding Al is harder then steel - how much welding experience do you have?
The two metals together, I'd advise against trying, try another method.
L
Answer 11 years ago
I don't want to weld the 2 metal together just like to know to how to do each one I make jewelry with different metal, and I know some people allgeric to nickel whick the sterling silver I am using they can't wear but these 2 metal they could, just try to widen my market.
Answer 11 years ago
For jewelery you would be better not welding I think, as it gets difficult on a small scale.
L
11 years ago
There are many good tutorials online about soldering aluminum and stainless (check Google), but are you sure soldering is what you want? Also check into brazing and welding, as those techniques may be more suitable for whatever it is you're trying to do.
Answer 11 years ago
I am making jewelry with the stainless steel and aluminum, I like to solder the ring close and making design with the wires.
Answer 11 years ago
Sounds like soldering would be the way to go, then.
Answer 11 years ago
...but you can't weld aluminium to stainless. You CAN braze or solder them.
Answer 11 years ago
Quite so. Just trying to cover the bases in the absence of any details about what we're trying to accomplish....
11 years ago
If you end up welding stainless steel, only do it outside with lots of ventilation. Stainless steel may vent cadmium and other bad metals when melted during welding.
Answer 11 years ago
Cadmium ? Chromium, sure, but I don't know any standard series stainless with any cadmium in 'em - its too volatile. Damned stuff boils at 800 C
Steve
Answer 11 years ago
You might be right. Probably are. I don't use any of the stuff but picked up the info when researching an electrolysis project. Thanks for pointing that out. Still not good to breath the fumes.
11 years ago
TIG is your best bet in either case, but aluminum can be welded using a MIG rig.
You will ot be able to weld aluminum to stainless steel. period. Generally speaking, "welding" requires use of Metal A to Metal A, not metal A to metal B
