6673Views9Replies
I am looking for hand tool that will punch a hole in a a variety of coins to use when making a 550 cord bracelet.
I am loking for hand tool that will punch a hole in a a variety of coins to use when making a 550 cord bracelet. So the hole can't be much bigger than the width of the cord..any suggestions? and if so where can i get one...?
11 years ago
have you tried just putting the coin in a vice and using a drill?
Answer 3 years ago
Costly, potentially dangerous, time consuming and actually somewhat expensive. A Whitney Punch is better, all-around.
10 years ago
I am having the same problem. I have broken two hole punches from Fire mountain catalog. Seems like there are alot of variation in the metal types of coins, especially foreign coins. I have tried drilling, but having a problem with the drill or coin sliding. I need to find a punch similar to the one Fire Mountain sells, only more heavy duty, that punch works very well on lighter metal coins for a short time.
Answer 10 years ago
use a drill press and a center drill to start the hole in the coin. Then drill it to size with the correct drill. Starting with the center drill will keep the actual drill from wandering. You can also use "jobber" drills, which are much shorter than standard drills, and they will even be less likely to wander too. Check out Enco (www.use-enco.com)
11 years ago
use a drill
11 years ago
There's a whitney punchdisk cutter or screw punch depending on how big the hole needs to be. The Whitney punch has several different dies, the screw punch only has the two, and the disk cutter is limited in where you can position the hole.
11 years ago
You can get a hand metal punch tool on EBAY. Search for the words :Hand metal punch tool.
11 years ago
. Hand tool? Do you mean human-powered or it will fit in your hand? Punching a hole in a coin with a hand-operated press will require quite a bit of leverage. I'd go with a hydraulic press and a set of dies. Vince 09's drilling suggestion is probably the best all-around solution.
