88Views1Replies
Author Options:
I came across several steel plates, 2 stees blocks, and an alumanum block any ideas on what i could build with these? Answered
The demintions of the steel plates are roughly as follows. 6"x9.75"x0.5in I also has a 3/4" hole drilled about 1 1/4" from the top. The next plate is about 3"x16.25"x3/4" it too has a hole that's 1" in dimater and 1 inch from the top. The next plate is really beat up but it's about 5.5"x4"x1/2" it has no holes. The next plate is 9"x2.25"x3/4" it has 3 holes the first one is 1.5" in diamiter and about 1.5" from the top the 2nd and 3rd holes are about 1" in diamiter and about 6.25" and 8" from the top. The next sheet is slightly bent somehow but its about 8.75"x3.5"x.5" it has 2 rows of holes each measuring 3/4" and the rows are 1.75" apart, there are 5 holes in each row and each one is 1.25" from the next the rows start 1.5" from the edge. That piece was hard to describe and I proboly didn't do a great job but now were on to the Blocks. The first block is 3.5"x2.5"x2" and has 2 holes on the 3.5"x2" sides that are 1" is diameter 1/2" from the sides and 2" apart. The next block is 8"x3.75"x3.75" with 2 holes. The hole are on the one of the 8"x3.75" sides and are 3/4" in diameter there 1" From the closest 2" side and centered (just as the holes are unless otherwise stated). And the aluminum block is 11.75"x2.5"x1.5" with no holes. If you guys thing of anything cool or useful I could build with these it would be much appreciated. If Anything was unclear please feel free to ask.
Note: I messured the distances to and between hole from the center of the hole
