I can't connect to my Etherten is something wrong with the code or the browser?
The code compiles in arduino 1.0 and uploads but when i connect to it through my browsers(firefox and internet explorer) it says internet exploerer cannot display the webpage and on firefox its just blank.
here is the code
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = {
0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
byte ip[] = {
192,168,2, 77 };
EthernetServer server(80);
int LED = 15;//Analog pin 5 (yes it works as a digital pin too)
void setup()
Ethernet.begin(mac, ip);
server.begin();
pinMode(LED, OUTPUT);
#define BUFSIZ 100 //Buffer size for getting data
char clientline[BUFSIZ]; //string that will contain command data
int index = 0; //clientline index
void loop()
index=0; //reset the clientline index
EthernetClient client = server.available();
if (client) {
boolean currentLineIsBlank = true;
while (client.connected()) {
if (client.available()) {
char c = client.read();
if(index<BUFSIZ) //Only add data if the buffer isn't full.
clientline[index]=c;
index++;
if (c == '\n' && currentLineIsBlank)
client.println("HTTP/1.1 200 OK");
client.println("Content-Type: text/html");
client.println();
client.println("<h1><center>Arduino Home Automation</h1></center><br><center><form method=get action=/?><input type=radio name=L1 value=1>Relay1 On<input type=radio name=L1 value=0>Relay1 Off<br><input type=submit value=submit></form></center>");
break;
if (c == '\n') {
else if (c != '\r') {
currentLineIsBlank = false;
if(strstr(clientline,"/?L1=1")!=0) { //look for the command to turn the led on.
digitalWrite(LED, 1); //turn the led on
} else if(strstr(clientline,"/?L1=0")!=0) { //look for command to turn led off.
digitalWrite(LED, 0); //turn led off
delay(1);
client.stop();
Thanks in advance
9 years ago
I had some similar problems, solved by plugging in an external power supply as well as the USB cable from my computer.
9 years ago
I had a similar problem with an Uno and Ethernet Shield, and after pulling all my hair out, i decided to recompile and upload using .22 instead of .23 of the IDE, and that solved my problem. Have you tried that?
