265Views8Replies
Author Options:
I guess you call this homework? Answered
BUT It isn't my home work.
A friend Emailed me this and asked if I knew how to work it out.
Th answer was no - do any one help - No teaching involved here my friend is in his 70's.
A car engine has four camshafts each supported by three journal bearings. The engine runs at a maximum of 8000rpm, and the camshafts rotate at half engine speed. Assuming the engine oil to be 40 degrees - Determine the maximum power absorbed by the camshaft bearings. Other data given below
journal bearing = 35 mm
bearing axial length = 20 mm
radial clearance = 0.018 mm
oil grade = vg32
oil density = 890kg m   ̅³̇
steveastrouk
steveastrouk
Best Answer 7 years ago
Here's the maths
http://books.google.co.uk/books?id=7QNWNReOUocC&pg=PA162&lpg=PA162&dq=Petrov%E2%80%99s+equation&source=bl&ots=XKL_yBpkhw&sig=uGft5-4Pzepaf1F69MxvCpygHaw&hl=en&sa=X&ei=kqEXU-_NMOiJywOjpoHACg&ved=0CF0Q6AEwBA#v=onepage&q=Petrov%E2%80%99s%20equation&f=false
rickharris
rickharris
Answer 7 years ago
Thanks - you must go to work early
steveastrouk
steveastrouk
Answer 7 years ago
petrov equation is what my office copy is based on anyway, and you can follow the maths. Like I said though, it's only a very crude approximation, because the minimum film ithickness is really <<2um, only that's almost a line
rickharris
rickharris
Answer 7 years ago
Ta, Students !
steveastrouk
steveastrouk
7 years ago
Tricky, because the actual oil film in a fired engine bearing is not uniform, but highly thinned in the area of maximum pressure.
I've got all the maths at work for the power calculation: we use it all the time. Power is propotional to the viscosity x (gap/peripheral speed) ^2
rickharris
rickharris
Answer 7 years ago
Any help is appreciated
mh76dk
mh76dk
7 years ago
Seems a common text-book example (I have no idea if the given answer is actually correct):
http://answers.yahoo.com/question/index?qid=20120528071554AAgnSYY
rickharris
rickharris
Answer 7 years ago
Thanks, looks like a lazy tutor.
