77Views5Replies
Author Options:
I have 4 cycl car if loss compression would make car no go well and die? Answered
Tags:car
Metal_maestro
Metal_maestro
5 years ago
It all depends on how much compression is being 'lost.' I know of a few vehicles that I have driven that have multiple cylinders that are missing but it still performs well enough. The age of your car will also make a difference. Computerized engines tend to not like anything that isn't optimum. Where an older car will shrug and get on with its life.
If your car is making a blue smoke screen and is gutless while driving. There is a good chance you have bad no go and die kind of compression loss.
harry88
harry88
5 years ago
If the engine isn't starting very easy this is usually a sign of low compression. I recommend buying a compression testing kit and measuring each cylinders pressure then consult your owners manual for the correct pressure range.
Vyger
Vyger
5 years ago
Loss of compression is usually a result of either a broken or failed piston ring or a failed head gasket. It could also be a result of bad valves not sealing or a timing belt that has gotten off its mark.
Any of those things will make it "no go" and run very badly or die.
steveastrouk
steveastrouk
5 years ago
Yes. Absolutely certain. And it will probably burn oil like there is no tomorrow.
iceng
iceng
Answer 5 years ago
+4 one for each cylinder...
