216Views9Replies
Author Options:
I have a LED i cant light, no matter what. It has a little black dot in it. What kind of LED is that? Answered
Appearance:
It is a common 5mm, transparent case, LED, being different from all others only by having this very tiny square dot over its anvil, kind of covering the reflexive cavity where the semiconductor (i don't know which) gets lit up.
Other:
I could not light this LED whit voltages from 1.5V to 3.5V. =O
It came out of a photocopying machine, and was paired with an IR LED in some kind of emitter-receiver set. Other components of this set were a pair of smd resistors and a smd trim pot.
Would it be and IR receiver or photodiode?
UPDATE:
I've took some photos of the mysterious LED. BUT, as no macro-enabled camera was available, i had to do the ghetto-way of photography. Soo: i have photos of it compared to the IR LED, and some photos of both anvils (IR, unknown), at 200x magnifying. Here they are.
BTW, i hadn't tested the suggested circuits yet. =(
Kiteman
Kiteman
Best Answer 11 years ago
Paired with an IR-emitter, it will be a photo-transistor.
It works like a normal transistor, except the 3rd leg is replaced by the light shining on it.
Connect it in series in a simple circuit, say an LED, and the LED won't light.  Shine a light on the component and it will switch and allow current to flow.
vinacarv
vinacarv
Answer 11 years ago
I've done the circuit. Works perfectly!
Thanks.
Kiteman
Kiteman
Answer 11 years ago
You're welcome - thanks for the "best".
Bigev
Bigev
Answer 11 years ago
*Hastily scribbles note*
Shine a light on the component...
bakermiro
bakermiro
8 years ago
That LED is Infra Red IR you can check it with phone camera
if it doesnt work it is a phototransistor or Photodiode .
lemonie
lemonie
11 years ago
It'll be and IR paper / mechanism detector like you suggest. Look at the LED with a video camera (assuming it's not been fried already), the photodiode won't emit light.
L
vinacarv
vinacarv
Answer 11 years ago
I did that. Actually that was the method i chose to verify if my IR wasn't really a BLED (in the words of robotguy4).
Obviously, the IR shone on my camera, but the other one, nope.
lemonie
lemonie
Answer 11 years ago
Well, as we've said (e.g. Kiteman) the other part won't emit light.
L
vinacarv
vinacarv
11 years ago
Photo posted. Take a look!
robotguy4
robotguy4
11 years ago
STARTING SIMPLE:
Did you check your polarity?
Hmmm...  It could be a BLED. (note: the B stands for "Broken")
