1667Views9Replies
I have a burned diode with no markings, can someone help me identify it?
I checked the resistance with multimeter and it gives me 130 ohms both side and I checked it with diode checker and gives me 0.065 v on both side.
Best Answer 10 years ago
This might seem like a dumb question, but regarding the tests with the multimeter, were these done with the diode still attached to the rest of the circuit?
Picture 4 shows this diode maybe wired to two sides of that relay.
I am guessing that this is an ordinary silicon diode (e.g. ln4148), and that is wired in parallel with a relay coil, for the purpose of absorbing the current in the relay coil when this is turned off suddenly.
If you put an ohmmeter across such a diode while it is still connected to the circuit, all you'll measure is the resistance of the relay coil, and 130 ohms sounds like a believable number for this.
Answer 10 years ago
Yes it was in circuit I took it off and it measure 0.650 ohms and 0.475 v oneway. Thanks
Answer 10 years ago
Glad I could help somewhat. Hope you get this alarm whatchmacallit, whatever this thing is, fixed, or if you don't succeed in fixing it, I hope you find some entertainment, and/or enlightenment, in the process of taking it apart.
10 years ago
Any idea what its for ? It LOOK like a boring LL4148, but it might be a Zener.
Steve
Answer 10 years ago
yes it does look like LL4148 Fast Switching Diode
Answer 10 years ago
How about a photo of the whole board ?
10 years ago
What's it in?
If you can find a schematic, that should at least tell you what general kind of diode it is -- ordinary versus zener vesus whatever.
Odds are pretty good that you can replace it with any diode which can handle the current and have the circuit at least limp along. The exact details of switching speed and transfer curve do matter in some circuits, but in many they don't.
The more important question is: What caused it to fry in the first place? Until you resolve and fix that, there isn't must point in installing a new diode and frying that one.
Answer 10 years ago
It's in a wireless home alarm system. The system fell from the wall, and the dc adaptor supply jack broke and caused the system to malfunction.
Answer 10 years ago
(Should have said "current and voltage", but I'm guessing that a surface-mount device doesn't have a lot of either running through it.)
