15350Views7Replies
Author Options:
I have a hole in the bottom of my dishwasher is there any glue or etc that can be use to fill the hole? Answered
Breaduh
Breaduh
3 years ago
We spent almost $50 trying to patch a hole in our dishwasher tub caused by a broken heating element melting through it. We tried several different epoxies, silicon caulk, dissolving pvc shavings into a paste. Nothing held as it was right under the element and the heat would affect the bond. What finally worked for us was JB Weld Plastic BOND (not plastic weld...we tried that first). We had to confirm what material our tub was (polypropylene) to figure out what would mesh with it. Just letting everyone know what worked for us!
Roobailey
Roobailey
Reply 2 years ago
Was the JB weld plastic bond you used?
https://www.walmart.com/ip/J-B-Weld-50139-Plastic-Bonder-Paste-Adhesive-85-Oz/168950018?wmlspartner=wlpa&selectedSellerId=1235&adid=22222222228065477421&wl0=&wl1=g&wl2=m&wl3=170070988765&wl4=pla-277099759858&wl5=9059879&wl6=&wl7=&wl8=&wl9=pla&wl10=112354589&wl11=online&wl12=168950018&wl13=&veh=sem
I tried the JB weld waterstop before finding this thread and it only held for 4 uses before turning loose. The hole is directly under the heating element. I have a whirlpool gu1500xtlb3.
Ldesa
Ldesa
3 years ago
I had a couple small holes in the bottom of my dishwasher tub. What caused them I'm not sure. The areas where these small holes were, looked like abrasions and the plastic was powdery. Cleaning out the abrasions revealed the small holes. After cleaning the area I applied FlexSeal (white) with a brush and let it cure for 24 hours. This worked great!!
ubdussamad
ubdussamad
8 years ago
just take some clay and split hardly all over the crack or hole and leave the dishwasher for 1day then you can easily use it cause the clay gets hard taking some time !
iceng
iceng
8 years ago
Is it a hole really or a crack ??
Figure of speech can have a major affect on how it is treated.
A hole is easy to fix when compared to a split.
For a hole put some rtv ( silicone ) and a plastic thumbtack over it..
A split is way harder to describe here...
A
framistan
framistan
8 years ago
I would clean the area and dry it first so the glue will stick. Do this to both sides of the metal if you can. Then smear some 100% silicone glue on it. Place a small piece of metal over the hole also. This gives more surface area for the glue to stick to. If you don't have a piece of metal just use a clean shiny penny. Do this to both sides and that should fix it. Silicone glue is good for this purpose because it is flexible and very waterproof and it sticks to almost any surface. Some other glues may not have all 3 of those properties and that might cause other glues to fail.
Jack A Lopez
Jack A Lopez
8 years ago
My intuition says to go with RTV silicone, also called silicone seal, also called silicone caulk, and it may be known by other names too.   It sticks to a lot of stuff, and when cured it is waterproof, and can withstand boiling water temperatures.
Of course I kinda have to wonder:  how big is the hole?
If the hole is larger than about 1 cm (or 0.5 inch) in diameter, then it might be better to make some kind plate, or patch, and then using the silicone seal, sort of glue that patch over the glue.
