99Views5Replies
Author Options:
I have a question about the wiring a 555 Timer in Monostable Mode? Answered
Hey all I am relatively new to the world of electronics. I have been learning about the different modes of the 555 timer chip because I would like to incorporate it into an upcoming project. I made a circuit and did the calculation so that once a button was pushed, an led would stay on for 5 seconds and then go off (a one shot timer). Everything worked ok accept I noticed that when hooked the battery up to the bread board (my last step of the build) the LED would turn on stay on for 5 seconds then shut off.  Is there a way to wire it so that when power is initially applied to the circuit it doesn’t trigger the timer? In other words the only thing I want to trigger the chip is a push of the button, nothing else! please let me know if this make sense. Thanks!
Josehf Murchison
Josehf Murchison
5 years ago
Yea the 555 timer will do that on power up when used as a oneshot if your button goes to ground. Try a oneshot circuit where the button goes to vcc.
Mpc1055
Mpc1055
Answer 5 years ago
will do thanks!
steveastrouk
steveastrouk
5 years ago
Usually because pin 2 isn't pulled up, put a 4.7k resistor to the supply and pin 2.
Mpc1055
Mpc1055
Answer 5 years ago
Steve, This is the schematic I am using, shouldn't the 10K resistor due the job that the 4.7K that you are calling for do?
Mpc1055
Mpc1055
Answer 5 years ago
I do have on on there, I must have wired it wrong! Thanks for the advice!!!!!
