The RV water pumps draw 5 amps. You can run it with a 2/10/30 amp bttery charger. Just run it in the 10 amp charge mode.
The newer shurflo pumps are garbage. Hopefully you have an older one from '95 or before.
The people at Shurflo changed the brushes in the motor so that they wear out after 20 hours of running. I'm sure this was done so that if someone's water tank ran out of water then the pump would be dead next time they tried to use it (the pump would run continually without water)
The older Shurflos had harder brushes and you could get years out of one. The only thing that would wear out was the bonze bushing in the pump assembly. The motor was bulletproof.
Best,
John Cadman
It depends upon how much output your 12v charger will give and how much the pump needs. Do they have any information on them in the way of Amps / Watts?
L
11 years ago
The RV water pumps draw 5 amps. You can run it with a 2/10/30 amp bttery charger. Just run it in the 10 amp charge mode. The newer shurflo pumps are garbage. Hopefully you have an older one from '95 or before. The people at Shurflo changed the brushes in the motor so that they wear out after 20 hours of running. I'm sure this was done so that if someone's water tank ran out of water then the pump would be dead next time they tried to use it (the pump would run continually without water) The older Shurflos had harder brushes and you could get years out of one. The only thing that would wear out was the bonze bushing in the pump assembly. The motor was bulletproof. Best, John Cadman
12 years ago
It depends upon how much output your 12v charger will give and how much the pump needs. Do they have any information on them in the way of Amps / Watts? L
12 years ago
no. your best bet is a 12 volt DC converter similar to this http://eugene.craigslist.org/ele/1063869822.html
