2648Views11Replies
I have been asked to investigate how to make "a crystal stone the size of a tennis ball or a bit larger." low budget
As part of a very low budget film I have been asked to research how to make a prop from the following specification
"We need a crystal stone the size of a tennis ball or a bit larger. It can be any shape but it must have colour (real of illuminated)."
The reference has been given as a Copper Sulphate Crystal we are an a deadline for mid Feb so any help would be fantastic
I have added reference pictures also
All responses gratefully received
Regards Peter?
Best Answer 9 years ago
When I was a kid I used to grow sugar crystals, many of which were baseball size and almost any color I wanted. All it requires is supersaturated sugar water, some cotton string, food coloring and time.
Just google how to make rock candy and get started. Its almost ridiculously easy.
Answer 9 years ago
Thanks very much for the message I will look into it how long would it take to grow a sugar crystal that size? we are on a tight timescale
regards Peter
Answer 9 years ago
There are a lot of variables but if your solution is completely saturated and you use a very large mouth jar in a low humidity environment, you should have some good results within a couple of weeks, depending on how big you grow the crystal.
Answer 9 years ago
Excellent will definatelly give it a go
Cheers Peter
6 years ago
how do you make a big crystal
9 years ago
you could grow a sugar crystal with an led in the center..that would look cool.
Answer 9 years ago
thanks very much will have a go and see how it comes out
cheers Peter
9 years ago
OK if you would be happy with something solid rather than clear - Get a lump of polystyrene - the stuff used for packaging or insulation. Available from your local DIY store
You can carve this with a hot knife (do it outside the fumes are unpleasant) or
You can carve it with normal hand tools- saws - files - sand paper - very easily and fast to the shape you want - then paint it with water based paints.
Its cheap as well. If you can find suitable packaging then free
Answer 9 years ago
Thanks again Rick,
we are looking for something that can be illuminated so it looks like it has an inner glow as it it to represent a fuel cell which either can be fully charged (illuminated) or in various stages of charge.
So we might need to create a resin crystal which we can colour with various lighting perhaps
cheers Peter
9 years ago
Believe me you will be FAR FAR better off moulding something in a clear or colored resin. You can get spherical candle moulds that will work for this.
If you can handle a solid color then colored plaster would work and be even cheaper.
Answer 9 years ago
thanks very much Rick that is the way that I am thinking also but I do not know how to do this either.
We are looking for something that looks like a crystal shape etc but is not actually a crystal so would welcome an instructable on how to fashion a fake/prop crystal also.
thanks for the response
Cheers Peter
