1798Views79Replies
Author Options:
I have built the Valve Caster circuit. I am having a horrible fuzz coming from my speakers. How can I fix this? Answered
This is a question that adds on to a previous discussion that involved a custom tube circuit using a 12AU7 tube.  I have gotten the Valve Caster to have output sound. signal goes from the guitar to the Valve to the preamp then to the amp. The amplifier did not have the fuzz until the Valve was put in. now I have a fuzz that sounds similar to that of rushing water. how can I fix this? I was contemplating putting the Huminator circuit in to correct this but I didn't know if that would work for this. the amp layout that I have here is roughly the same layout as it is in in reality
ChrisH1957
ChrisH1957
1 year ago
I had this problem too. I found this circuit to be very sensitive to power supply noise. My solution was to use a battery. The pedal will use up a 9volt battery quickly so I went with a Milwaukee 12vdc rechargeable battery.
iceng
iceng
8 years ago
The Huminator is a Low-Pass network But first you need
a sound to pass through it...
You are a nice polite guy but hung up on a 9v circuit of dubious
internet engineering, when the 12AU7 or any gas tube has a break
over voltage some where in the 50 VDC range.
Are you sure that there is a true 12Volts going to the heater ??
IF not ALL Bets are off this table.
A
fastcar123
fastcar123
Answer 8 years ago
Actually I have 9vdc running through my heaters. I have 3 transformers in play right now (9vdc, 12vdc, 15vdc) when I connect my tube to my 12vdc, it draws so much current that it completely robs the amplifier of all power. I could find a second 12v power source just to try it though
gmoon
gmoon
Answer 8 years ago
The Valvecaster circuit has been built by hundreds of DIYers (including me), and generally works fine with 9V for both heater and plate voltage. You'll get more gain with 12V, but I don't think that's your problem.
The 12au7 heater draws 125mA (0.15A), which isn't much power. If only adding 125mA to your power supply effects the power amp so much, maybe the amp itself is overtaxing the power supply, which could be leading to some of your problems...
Transformers themselves can introduce noise, so the placement of them (assuming they are inside the amp cab) can be problematic...
fastcar123
fastcar123
Answer 8 years ago
What do you suggest I do?
gmoon
gmoon
Answer 8 years ago
Find a bigger, more capable 12V power supply, preferably a quiet switching supply...
fastcar123
fastcar123
Answer 8 years ago
From where would I find a quiet switching power supply? I have a 500mA wall wart in now but it lacks the ability to power both the tube and the amplifier board. The 12v power supply also supplies things such as power LEDs
gmoon
gmoon
Answer 8 years ago
Check ebay for a switching supply. Thrift stores usually have a bin of wallwarts for a dollar or so, I like to check those periodically (most switching supplies there will be 5V, but sometimes you get lucky).
500mA is definitely too small for a 15W amp (and is that continuous or peak?). Assuming 50% efficiency, 30W/12V == 2.5 amps.
fastcar123
fastcar123
Answer 8 years ago
what exactly is a switching supply?
im not sure it was advertised as 15watts per channel. so I imagine that's the peak however it is louder than my other 2 15 watt amplifiers so im stumped
as for your equation it would explain why I cannot power the amp with the 12v source and why I cant crank up the volume with out getting an identical transformer failing sound (pulsing loud hum alternated with complete silence)
iceng
iceng
Answer 8 years ago
A Good Question from anyone,
especially a nice polite guy hung up on 9Volts :-)
There are two general types of (PS) Power Supplies ;
  1. Analog PS use a transformer that is rated for the output current and mains frequency.  A 12V 5A PS in the UK  50 Hz will be heavier then a 12V 5A PS in the USA 60 Hz
  2. Digital Switcher PS uses a High Frequency transistor switching at 20KHz_to 250KHz and only needs a small transformer to step down the voltage to produce 12V 5A.
The switcher PS may be less then a fifth the weight of an Analog PS
UK or USA and less expensive too.
So why are people still buying and using Analog PS ??
A
fastcar123
fastcar123
Answer 8 years ago
so basically a switching PS is simply one that uses a bit more electronics (such as a wall wart) and costs less and weighs less. correct?
iceng
iceng
Answer 8 years ago
Correct in Every thing but  [ wall warts = Analog ].
Wall Warts which as a rule are Unregulated failure prone transformers
with a DC bridge, known as TR (Transformer Rectifier) units.
A
gmoon
gmoon
Answer 8 years ago
Not so true, anymore. Just about all wallwart cell phone / Ipod / mp3 chargers now are switching power supplies. I have several external USB harddrives, and all but one have switching warts.
The largest selling 9V guitar effect box PS (the 1Spot) is also a switching supply. I own two of 'em.
It's kinda freaky how light a switching wall wart is--no big iron inside...
fastcar123
fastcar123
Answer 8 years ago
So everyone is sure it's the power supply?
What about when I connect it to the golf cart battery. Wouldn't that be the most direct current that could possibly be available?
iceng
iceng
Answer 8 years ago
Yes,
A charged golf cart battery is the ultimate steady ( smooth ) DC supply.
A
fastcar123
fastcar123
Answer 8 years ago
Then it can't be the PS because the fuzz is still there even when the PS is a large 12v battery
gmoon
gmoon
Answer 8 years ago
A battery replaced all the power supplies?
Regardless, You'll need a higher capacity PS for your power amp. 550mA isn't near enough for a 15 watt amp.
Personally, I would pull the Valvecaster from the boxed-up amp, and try it (by itself) with your other amp. And use the battery for the 'caster PS.
If it still sounds wonky, you've narrowed it down to the tube project. Then it's something like a wiring error, bad tube, bad cap, bad socket, wrong resistance value, or lack of shielding in the Valvecaster.
If the 'caster works OK with the external amp, but not in the boxed up project, then it's responding to noise in the component stages--PS noise (maybe em), ground loops, shielding problems, wire routing, etc.
And noise problems can be cumulative, i.e., come from multiple interactions...
fastcar123
fastcar123
Answer 8 years ago
Resistance values? Take a look at the valve caster project. My R4 consists of 3 resistors that were supposed to be 470k ohms. However all of my 470k resistors were below specification. They all measure around 150k- 200k. I thought putting the 3 together would make a 470k. Now that I actually measured it it measures 1123k which has me bamboozled. What exactly does R4 do?
gmoon
gmoon
Answer 8 years ago
R4 on the Valvecaster is part of the RC network (coupling) that connects the first to the second stage. See RC filter calculator. 1M or 470K, going to more R is probably not a big difference in this case. Other resistors (such as plate load or cathode bias) would be more critical.
Looking at your photo, I see a lot of connections that are just twisted together. If you haven't, you really need to solder connections. Cold solder joints (or no solder joints!) are another source of noise...
fastcar123
fastcar123
Answer 8 years ago
Actually what you're seeing is in fact soldered joints with electrical tape wrapped around them to prevent short circuiting. I don't think I have cold solder joints either. The way I solder 2 wires together is I have the iron on the joint, I push in about a half inch of solder and leave the iron on the joint for a while after
gmoon
gmoon
Answer 8 years ago
OK, that's good (cold solder joints can still cause noise).
Best I can suggest now is that you test the different stages separately, to see if you can narrow down the source.
Keep in mind, though, that PS noise could come from a different power supply than you're using with the Valvecaster...
As you have found, noise issues with audio eq can be really difficult to troubleshoot.
fastcar123
fastcar123
Answer 8 years ago
After Christmas im going to change out the PS replace the heater wires and signal in and out wires for wires 2 gauges thicker, put in a never used tube and resolder ever joint I have on the caster. If that doesn't fix it I doubt anything will
gmoon
gmoon
Answer 8 years ago
I always use little clip-on heat sinks when I solder capacitors. Too much heat during assembly can damage them.
Just another thing to think about...
fastcar123
fastcar123
Answer 8 years ago
What do you mean clip on heat sinks?
gmoon
gmoon
Answer 8 years ago
 They are small aluminum clips; mine don't match, but look close to the photo below.
I don't know your location--Radioshack in the US has something different that works, too. Or searching for "soldering heatsink" will turn up something.
Anything similar to an alligator clip will help sink the heat--aluminum is preferable, but a steel clip is better than nothing...
iceng
iceng
Answer 8 years ago
+1
iceng
iceng
Answer 8 years ago
Yes it cannot be the PS,
leaving the wiring, the components and the design.
Now what ?
iceng
iceng
Answer 8 years ago
I will agree PC, Camera, Apple and related equipment will be using
HF switcher supplies But a good many cheep warts are the
unregulated analog type..
fastcar123
fastcar123
Answer 8 years ago
I will be ordering it after christmas
iceng
iceng
Answer 8 years ago
Avoiding the XMAS chaotic shipping surge is smart
fastcar123
fastcar123
Answer 8 years ago
I would need something like this but the 3A model?
iceng
iceng
Answer 8 years ago
A good deal !
iceng
iceng
Answer 8 years ago
When you are ready i will gladly explain 4 terminal PS like the 3A you like.
i'm pleased to help you because of your excellent
Modding and cleaning an electric guitar ible which
taught me some things I did not know :)
fastcar123
fastcar123
Answer 8 years ago
thank you im glad I was able to teach you some things :D
iceng
iceng
Answer 8 years ago
BTW 125ma = is actually = o.125A just under o.15A
Looking through your ibles I see your more then adequate at electronics
a superb craftsman and guitar player.
Still I have the hardest time believing that a tube will conduct gas ions at 9V..
Most of your ibles provide great videos however not on the V-caster ???
gmoon
gmoon
Answer 8 years ago
Yeah, that's just mistyped (dropped the 2), not a lack of understanding that milli means 1/1000. ;-) I still hate the fact that we cannot edit posts here. It's a shame; an oddly lacking feature for an otherwise professional website.
Still, I am not an EE (not an engineer of any kind), and perfectly aware of my hobbyist stature...
The valvelitzer is my project, not the valvecaster (the inspiration, though). Fastcar123 is trying to build the 'caster. I've tried to help fc123 in the past, with mixed results. It's tough to debug over the internet, especially with limited photos...
My ValveLitzer video lacks real-time footage because I was going for better audio quality, which my cheesy camera lacks. I have excellent still cameras, but not video. It's probably time to revisit that project, which was only a prototype--make a few changes, a more professional look, and new video.
fastcar123
fastcar123
Answer 8 years ago
I tend to get frustrated with things, and with limited knowledge and supplies it makes things harder to debug
iceng
iceng
Answer 8 years ago
Likewise I do that too,  .....  but not as often as I would like...
gmoon
gmoon
8 years ago
There's nothing wrong with your audio signal chain--so long as it worked before you added the tube stage. All guitar amps have internal preamplifiers (and you've built your own amp), so...
Valvecaster->preamp->power amp
...is correct. The Valvecaster is an external "stompbox" effect, so it's generally first.
Unless there's something suspect about the preamp stage, such as low input impedance, it stands to reason that the problem was introduced with the Valvecaster build. Here's a couple thoughts:
--All these starved-cathode tube effects suffer from noise. Try the Huminator--it's a filter on the power supply, not the audio signal. Of course you can use it.
--Make sure the tube is good. Always have a backup tube.
--Recheck the Valvecaster wiring.
--The wiring on your homemade amp isn't good. You can certainly shorten a lot of those leads.
--DId you check how the valvecaster stage works before you boxed it inside with the amplifier? Proximity to that rat's nest can add noise...
Lastly, if you add an op amp stage (which won't solve your problem unless there's something wrong with your existing preamp), don't use the 741, it's noisy. Instead use a TL07x (TL071, TL072, TL074). It's pretty much the standard for guitar projects when a "clean" op amp stage is required.
steveastrouk
steveastrouk
Answer 8 years ago
I can't help but think this thing is going to attenuate the incoming signal significantly, hence sticking some front-end gain in strikes me as a good idea.
The 741'll work for a tryout, its cheap and easier to find than the TL07X - though I still have around 1000 in tubes at work.
The NE5534's very goof, but he's only trying out ideas.
gmoon
gmoon
Answer 8 years ago
Valvecasters are above-unity; they have more gain than you might expect.
Going by the datasheets, it shouldn't work at all--but it does. Depends somewhat on the internal construction of the tube itself. The higher gain "standard guitar preamp" 12ax7 tubes don't work well at all at these voltages.
You can try goosing the signal pre or post the effect, but with a typical guitar amp (input impedance >500K) the valvecaster alone should work fine.
They are VERY susceptible to noisy power supplies, though...
fastcar123
fastcar123
Answer 8 years ago
Aside from the huminator what else could I do?
gmoon
gmoon
Answer 8 years ago
Switching power supply, or some sort of regulated PS.
fastcar123
fastcar123
Answer 8 years ago
such as what exactly? a PC or Xbox supply?
steveastrouk
steveastrouk
Answer 8 years ago
Valves were before my time, and I've never been that much of an audiophile that I don't prefer my John Linsley-Hood 150W MOSFet amp I built at University 25 years ago.
I'm fascinated by this in some sense though. Its like operating a FET below the knee then ?
gmoon
gmoon
Answer 8 years ago
I guess so--it's definitely not in the linear portion of any of the characteristic curves...which is OK, it just happens the distortion produced by low voltage operation sounds pretty good, for guitar, anyways.
Probably wouldn't sound so great for any other audio applications, though...
fastcar123
fastcar123
Answer 8 years ago
The noise still comes even if I have the tube out side of the amp. There is no hum only fuzz and I imagine placing the tube near the transformers would cause a hum. So this tells me that the tube is far enough away. Would the huminator work for this? I have a second AU7 tube so ill plug that one in just to see if it sounds anydifferant, however both tubes were purchased from an audio store brand new. For the valve caster, I was able to get signal to come through it after many many tries. I'd rather not have to completely rewire it but I will if I need to. And for the huminator I have everything except the diode so I think I'll build it with out and just make sure I connect it right
For the record the amp did work with little to no fuzz, hum or noise before I had the tube in place
steveastrouk
steveastrouk
Answer 8 years ago
One reason for noise is that the circuit hasn't got enough signal to work with, and when you turn up the amp you end up amplifying the cruft out of the front end, as well as the tone from the guitar.
fastcar123
fastcar123
Answer 8 years ago
What if I placed it after the DS-1 Keeley moded distortion would tha help or would I still need more power?
fastcar123
fastcar123
Answer 8 years ago
my amp layout is at the top
