183Views4Replies
Author Options:
I have to remove a huge quantity of limescale (ca. 2 ton). Answered
Do anyone knows the better metod? I tried citric acid (some white powder resist), Hydrochloric acid is not possible to use (some parts are in stainless steel...). I was wondering acetic acid or EDTA.
steveastrouk
steveastrouk
11 years ago
What IS it made of ? Use another acid, sulphuric is safe on En316 stainless steel at LOW temperatures (<60F), and its cheap enough. Bear in mind it won't be acid for very long as you dissolve the scale - you're going to need a LOT of acid. Slosh it around, monitor the pH and you should be OK.
mauriziogio
mauriziogio
Answer 11 years ago
This is an evaporative tower. For several years we feed water without giving the chance to salts to flush away... Limescale is over hundreds and hundreds of meters of 1" pipe. The total thickness is more or less 5 to 10 mm. When i tried sulfammic acid (citric) i had a quantity of white powder on bottom.
frollard
frollard
11 years ago
A jackhammer comes to mind...
lemonie
lemonie
11 years ago
2 ton?! How about some heavy machinery? (More detail?) L
