1494Views15Replies
Author Options:
I need a detailed method of doing, and double checking Algebraic Quadratic equations? Answered
What I lacked in school, over 30 years ago, was a backbone to ask the teacher what he meant, but his hurried learn this style of teaching. What I need now, is something I have having trouble getting, even from any of the several books on the subject I have, that claim to make it simple: that is, I need both the methodology of doing the equations, and I need to know how and why they work, so I can work out when I have done something wrong.
Jack A Lopez
Best Answer 10 years ago
I think your best bet would be to kidnap a math professor, and then keep him or her hostage in your cellar. That way you'd have somebody available at any hour of the day to help you with your equations.
However, that would be highly unethical, and maybe impractical, especially if you're renting.
I think the next best thing to having a captive human math expert, would be some sort of captive robot. Making robots do boring work is not unethical, unless it takes away the job of a union member, but that'a another story. Here's the part where I give you the pitch for Octave.
http://octave.sourceforge.net/
If you want the ability to solve, or create arbitrary quadratic equations, Octave can do this.
Want to solve x2 - 6x + 8 = 0 ? Use the roots() function:
octave.exe:142> roots([1,-6,8])ans =   4   2
Want to create a quadratic equation with real roots at 5 and -3/2 ?
octave.exe:143> conv([1,-5],[1,1.5])ans =   1.0000  -3.5000  -7.5000octave.exe:144> 2*ansans =    2   -7  -15
In other words: 2x2 - 7x - 15 = 0
Many expensive graphing calculators have similar functionality. Of course the advantage Octave has is it is free, minus the effort of installing it, figuring out how to use it, etc.
GoodhartJack A Lopez
Answer 10 years ago
Whoa, 54 mb....even with DSL this'll take a bit to download..... I shall look at it though, thanks.
nghi1350
5 years ago
Here are the details on:"Solving quadratic equations by the new Transforming Method". This new methods uses 3 features in its solving process:
#*1. The Rule of Signs for Real Roots of a quadratic equation.
#*2. The Diagonal Sum Method that solves and immediately obtains the 2 real roots of equation type: x^2 + bx + c = 0.
#*3. The transformation of quadratic equations type ax^2 + bx + c = 0 into the simplified form, with a = 1.
#*The NewTransforming Method. It proceeds through 3 Steps.
#*STEP 1. Transform the equation type ax^2 + bx + c = 0 (1) into the transformed equation form: x^2 + bx + a*c = 0 (2)
#*STEP 2. Solve the transformed equation (2) by the Diagonal Sum Method, It proceeds by composing factor pairs of a*c following these 3 Tips:
*TIP 1. When roots have opposite signs, compose factor pairs of c with all first numbers being negative.
*TIP 2. When both roots are negative, compose factor pairs of a*c with all negative numbers.
*TIP 3. When both roots are positive, compose factor pairs of a*c with all positive numbers.
#*STEP 3. Suppose the 2 obtained real roots of the transformed equation (2) are y1, and y2. Divide both y1 and y2 by the constant (a) to get the 2 real roots x1 and x2 of the original equation.
#*Example 1. Solve: 6x^2 - 19x - 11 = 0. Transformed equation: x^2 - 19x - 66 = 0 (2). Solve equation (2) by the Diagonal Sum Method. Roots have different signs. Compose factor pairs of a*c = -66. Proceeding: (-1, 66) (-2, 33)(-3, 22). This sum is -3 + 22 = 19 = -b. The 2 real roots are y1 = -3 and y2 = 22. Next, find the 2 real roots of the original equation (1): x1 = y1/6 = -3/6 = -1/2, and x2 = y2/2 = 22/6 = 11/3.
#*Example 2. Solve: 16x^2 - 62x + 21 = 0 (1). Transformed equation: x^2 - 62x + 336 = 0, (2). Both roots are positive. Compose factor pairs of a*c = 336. Proceeding: (1, 336)(2, 168)(4, 82)(6, 56). This last sum is 62 = -b. The 2 real roots are: y1 = 6 and y2 = 56. Next, find: x1 = y1 = 16 = 6/16 = 3/8, and x2 = y2/16 = 56/16 = 7/2.
nghi1350
5 years ago
There is a new method, called "The New Transforming Method" to solve quadratic equations in standard form ax^2 + bx + c = o that can be factored. This new method is may be the fastest and simplest method. Its strong points are: fast, simple, no guessing, systematic, no factoring by grouping and no solving binomials.
Please read articles titled: "Solving quadratic equations by the new Transforming Method" on Google or Yahoo Search.
nghi1350
5 years ago
Best methods to solve quadratic equations.
The first choice is the quadratic formula since it can solve any quad. equation in standard form ax^2 +bx + c = o, when you can use calculators. However, there are some inconveniences and exceptions:
- You must remember by heart the quadratic formula.
- You must know how to extract the square root of a number when calculators are not allowed, in some test/exams for example.
- In some cases, other solving methods, such as the factoring AC Method and the new Diagonal Sum Method, are simpler and faster.
- Teaching instructions want you to solve quad. equations by other methods in order to improve your math skills.
When a quad. equation can be factored, there are 2 best methods to solve it.
1. The factoring AC Method that proceeds to factor the equations into 2 binomials in x. Then, it solves the 2 binomials for x.
Note. There is a "new and improved factoring AC Method" that was recently introduced by Nghi H Nguyen, the author (Yahoo Search or Google Search). This improved methods helps to solve quad. equations simpler and faster.
2. The new Diagonal Sum Method that directly finds the 2 real roots in the form of 2 fractions, knowing their sum (-b/a) and their product (c/a). You can read this new method in math articles titled:"Solving quadratic equations by the Diagonal Sum Method" (Yahoo Search or Google Search)
Padlock
10 years ago
Quadratic formula?
0=xa2+xb+c
futengPadlock
Answer 9 years ago
The negative boy had mixed feelings about going to the radical party. He didn't want to be square and not have 4 asian chicks. It was all over at 2am.
Chicken2209
10 years ago
you need to know how to do an equation? how so, example of a problem?
NobodyInParticularChicken2209
Answer 10 years ago
I may turn this into an instructable at some point...
If you are not completely comfortable with solving linear equations, please stop and review that first. It's much better to realize that you need practice with steering when you're in a car than when you're in a fighter jet.
My personal recommendation for solving quadratic equations is to start with the standard form and turn it into the factored form using three memorized shortcuts. I also suggest keeping your algebra readable by working on graph paper and neatly writing one symbol or number per box. Write a sign on every number.
Start by writing the equation in the standard form, y = ax2 +bx +c.
Write a=, b=, and c= on separate lines and fill in those numbers.
Write the formula h = -b over 2a and calculate h.
Write the formula k = c -ah2 and calculate k.
Write the formula z = sqrt( -k over a ) and calculate z.
Once you have c, h, k, and z, you can easily find anything. You can write the equation in factored form y = a(x -h)2 +k or you can graph and solve it:
Solutions: x=h+z or x=h-z
X-intercepts, if z is real: (h+z,0) and (h-z,0)
Y-intercept: (0,c)
Line of symmetry: (y=h)
Vertex: (h,k)
Here are five illustrations of the steps for an example problem:
Set up problem
Find horizontal part (h)
Find vertical part (k)
Find root/vertex distance (z)
Find solutions (x)
NoneNoneNoneNoneNone
NobodyInParticularpleabargain
Answer 10 years ago
Sadly, I didn't feel like learning how to use a program that is actually designed to do this. So I used Excel. You can hammer in a nail with a screwdriver, it just takes longer. : )
Answer 10 years ago
Quadratic equations can be written in the standard form y = ax2 +bx +c or in the factored form y = a(x -h)2 +k . When you are asked to solve them, this usually means setting Y=0 and solving for X = the roots (also known as X-intercepts or zeroes). There are many methods of solving. Some of them are the quadratic formula, completing the square, graphing, and factoring.
The best methods to use on y = ax2 +bx +c types:
*The quadratic formula is hard to memorize, but when you have it, solving is easy.
*Completing the square is terribly tedious, but its step-by-step nature helps you understand what is going on.
The best methods to use on y = a(x -h)2 +k types:
*Graphing just involves plotting points. It's tedious and imprecise, but not too hard.
*Factoring can be used to split your equation into two easier-to-solve linear equations. It doesn't always work.
Unfortunately, understanding why the methods work is considerably more trouble than actually using them. This may be why your teacher said, "here, memorize this". For example, the quadratic formula was built by completing the square.
GoodhartNobodyInParticular
Answer 10 years ago
Had you entered this as a post not replying to mine, I could have selected this as the best answer, but that option is not available to a reply
Answer 10 years ago
That would be GREAT (I am sorry I didn't get this asked in time to get it included in the MATH Burning Questions contest).
Had you posted this as a separate thread here, I could have marked it as the Best Answer
Thank you for taking the time to explain this: I will run through it more carefully later, and ask any questions I may have.
GoodhartChicken2209
Answer 10 years ago
What I mean is, back in school, over 30 years ago, I came to a dead halt in mathematics because I was unable to solve quadratic equations (other then very simple ones). I had wanted to push myself into one of the science fields, either computer science or electrical engineering, but I lacked the math background and my teachers were of NO help to me; unwilling or unable to explain the workings to me (this is why I liked Geo-trig better, as I could understand WHY we had to do such and such to find an answer). I know it is a little late for me to believe I could ever accomplish much in the field, but I would still like to be able to use the math form and understand the math in some of the physics books I currently read.
Padlock
10 years ago
Curse my infidelity. I wrote it wrong. I really meant...
fwjs28
10 years ago
ha...lol....the day after reading this, i was looking in my 8Th grade math book and guess what was in it...(no not pi to the 9,874,687,159,458,751 digit)
