141Views4Replies
I need a good way to very closely bind two strips of metal at a point.?
I saw and tested https://www.instructables.com/id/How-to-sharpen-a-knife-with-a-nail-clipper-2/
It works amazingly well, as long as you don't mind a few scratches on the blade. I like it but a nail clipper is way too small for a couple of my knives, (chef's knife, buck knife, etc.) I'd like to imitate the effect using a piece of steel I have. What would be the best way to attach the pieces together? I considered a pop rivet but I don't know it would stand up to much use or be tight enough.
Recommendations?
Best Answer 9 years ago
A few ideas;
Can you weld? Go for that.
Solder, which would work alright on steel. It's not exactly the strongest of choices though.
Glues like 2 part epoxy will not last for long, obviously, but you can reapply and it's (reasonably) quick & easy.
A pop rivet would still probably be a better choice, though...
9 years ago
Spot welding.
There are a few instructables on making a spot welder, but if you only need to weld this one thing, it may be easier to find someone who owns one (a mechanic, maybe...).
Cheers, Alex.
9 years ago
Try: bolt, washers, lock washer and nut. This has worked for a very long time.
Qa
9 years ago
Actually for the price they are it's far better to buy a knife sharpener that works in the same way but has carbide blades. this is the one I have from Amazon and I have never had such sharp cooking knives/ Also works with all other blades as well.
£9.25 in the UK. Worth every penny.
