130Views9Replies
Author Options:
I need a simple curcuit ? Answered
I need to turn on a 24vdc relay (apply gnd ) with a transistor. I have a 5v signal as the sourse from an industrial computer
Tags:dave
rickharris
rickharris
7 years ago
Like this? Of course you need a 5 volt relay coil if you have a 5 v supply
daveaprile
daveaprile
Answer 7 years ago
my sourse to activate the transistor is 5 v but rtelay coil is 24vdc
rickharris
rickharris
Answer 7 years ago
IF your going to use one relay to turn on the 24 volt relay you need a 24 volt source anyway, unless there is something your not saying you may as well just use the 24 volt source you will need anyway and a single relay driven by the transistor.
petercd
petercd
Answer 7 years ago
There's probably a better way to do it electronically, but I'd use the 5V relay to switch on the 24V power to the 24V relay.
steveastrouk
steveastrouk
Answer 7 years ago
You shouldn't drive the relay directly from the computer I/O pins
petercd
petercd
Answer 7 years ago
Actually I was thinking of an addon mod to the Rickharris circuit, meaning use that 5v relay to drive the other 24v one.
daveaprile
daveaprile
Answer 7 years ago
Thanks for your input
steveastrouk
steveastrouk
Answer 7 years ago
That will work just fine on 24V. Just don't forget the diode, its critical.
rickharris
rickharris
Answer 7 years ago
The transistor will turn on fully when it's base is at about 1 volt. In this diagram the relay has a 5 volt coil. but your is 24 volts (I assume that's what you mean) - replace the 5 volt supply with 24 volts and yours will work.
The BCX38C can handle up to 60 volts collector to emitter at 800 Ma.
If your only supply is 5 volts then you need to find a relay that operates off
5 volts
