I need arduino code help.
I want to do arduino time relay with RTC and LCD, but i have problems with the code.
This is my code:
#include "Wire.h"
#define DS1307_ADDRESS 0x68
#include <LiquidCrystal.h>
byte zero = 0x00;
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
int rele=7;
#define DS1307_I2C_ADDRESS 0x68
#define STA_HOUR 16
#define STA_MINUTE 15
#define STA_SECOND 0
#define END_HOUR 16
#define END_MINUTE 17
#define END_SECOND 0
void setup(){
Wire.begin();
Serial.begin(9600);
setDateTime();
lcd.begin(16, 2);
pinMode(rele,OUTPUT);
void loop(){
printDate();
delay(1000);
lcd.begin(16, 2);
void setDateTime(){
byte second = 0; //0-59
byte minute = 13; //0-59
byte hour = 16; //0-23
byte weekDay = 2; //1-7
byte monthDay = 2; //1-31
byte month = 8; //1-12
byte year = 13; //0-99
Wire.beginTransmission(DS1307_ADDRESS);
Wire.write(zero);
Wire.write(decToBcd(second));
Wire.write(decToBcd(minute));
Wire.write(decToBcd(hour));
Wire.write(decToBcd(weekDay));
Wire.write(decToBcd(monthDay));
Wire.write(decToBcd(month));
Wire.write(decToBcd(year));
Wire.write(zero);
Wire.endTransmission();
byte decToBcd(byte val){
return ( (val/10*16) + (val%10) );
byte bcdToDec(byte val) {
return ( (val/16*10) + (val%16) );
void printDate(){
Wire.write(zero);
Wire.requestFrom(DS1307_ADDRESS, 7);
int second = bcdToDec(Wire.read());
int minute = bcdToDec(Wire.read());
int hour = bcdToDec(Wire.read() & 0b111111);
int weekDay = bcdToDec(Wire.read());
int monthDay = bcdToDec(Wire.read());
int month = bcdToDec(Wire.read());
int year = bcdToDec(Wire.read());
lcd.print(monthDay);
lcd.print("/");
lcd.print(month);
lcd.print("/");
lcd.print(year);
lcd.print(" ");
lcd.print(hour);
lcd.print(":");
lcd.print(minute);
lcd.print(":");
lcd.println(second);}
if (minute = STA_MINUTE && hour = STA_HOUR)
digitalWrite(rele,HIGH);
if (minute = END_MINUTE && hour = END_HOUR)
digitalWrite(rele,LOW);
The errors :
chasovnik_lcd:104: error: expected unqualified-id before 'if'
chasovnik_lcd:108: error: expected unqualified-id before 'if'
7 years ago
I think you're errors are because there is a closing curly brace on the line preceding the if statements. The if statements don't appear to be inside a function.
7 years ago
I want to have clock with date on the lcd and at a specific time to activate the relay. With this code(without if statement), i have only clock and date. I can`t activate relay.
#include "Wire.h"
byte zero = 0x00; //workaround for issue #527
void setup(){
Wire.begin();
Serial.begin(9600);
setDateTime(); //MUST CONFIGURE IN FUNCTION
void loop(){
printDate();
delay(1000);
void setDateTime(){
byte second = 45; //0-59
byte minute = 40; //0-59
byte hour = 0; //0-23
byte monthDay = 1; //1-31
byte month = 3; //1-12
byte year = 11; //0-99
Wire.write(zero); //stop Oscillator
Wire.write(zero); //start
// Convert normal decimal numbers to binary coded decimal
// Convert binary coded decimal to normal decimal numbers
void printDate(){
// Reset the register pointer
Wire.write(zero);
int hour = bcdToDec(Wire.read() & 0b111111); //24 hour time
int weekDay = bcdToDec(Wire.read()); //0-6 -> sunday - Saturday
//print the date EG 3/1/11 23:59:59
Serial.print(month);
Serial.print("/");
Serial.print(monthDay);
Serial.print("/");
Serial.print(year);
Serial.print(" ");
Serial.print(hour);
Serial.print(":");
Serial.print(minute);
Serial.print(":");
Serial.println(second);}
Answer 7 years ago
Why did you remove the if statements? all you had to do was add the ';' where they where needed.
7 years ago
What problems are you having with the code? What results are you expecting and what are you getting.
BTW the errors your getting are telling you that your missing the semi colons at the end of the If statements.
