1515Views14Replies
Author Options:
I need help with coding a car cruisecontrol and Arduino Leonardo (HID)? Answered
Hi all, I have a challenge I cant solve, I need your help!
I have a car cruise control lever I want to connect to an Arduino Leonardo and have it act like a keyboard (HID).
It has only two wires, 3 push buttons and one toggle switch. I do know the input voltage is 5 volt and every button has its own resistor causing different voltages to come out when used. This way the car computer knows what has been pressed.
I have 3 switches:
1: Acc (Cruise Control Accelerate speed)
2: Ret (Cruise Control Retrieve speed)
3: Res (Cruise Control Resume from last speed)
I have one toggle Switch:
Cruisecontrol ON/OFF
I want the ON/OFF to toggle a keyboard character "C" when used.
I want button 1 to send a "7"
I want button 2 to send an "8"
I want button 3 to send a "9"
The code should pause after each change (no loop). The 10k Restistor is a pull-up resistor for debounce.
Anyone?
Project: https://hackaday.io/project/8448-real-dashboard-truck-simulator
steveastrouk
steveastrouk
Best Answer 5 years ago
You need to use an analog input then. "Debouncing" doesn't happen by adding a resistor at random.
Your Cruise switch has only two output wires ? Correct ? You will need to feed it FROM a resistor to the 5V supply, connecting the other to ground. Measure the voltage between the end of the resistor and the ground line. It should vary as the buttons are pressed.
Steve
Jeroenv26
Jeroenv26
Answer 5 years ago
Thanks for your help! You mean, like this:
steveastrouk
steveastrouk
Answer 5 years ago
Close ;-) Try this.
Jeroenv26
Jeroenv26
Answer 5 years ago
Like this:
Jeroenv26
Jeroenv26
Answer 5 years ago
Ok, and do you also know code to get my stuff going?
steveastrouk
steveastrouk
Answer 5 years ago
PS. Start with a minimal program that reads the A/D and prints a value to the screen 2 times a second.
Jeroenv26
Jeroenv26
Answer 5 years ago
Here is a start I made. It is a mix of the Arduino Ohm Meter Tutorial and my own Scania Retarder code. tinyurl.com/ho2me6w
I guess it needs booleaans and if/eleses and stuf to get keyboardprints and no-loop.
steveastrouk
steveastrouk
Answer 5 years ago
Get the naked button press values, and post them.
acc= ?
res=?
etc, don't bother with the combinations.
There is a trick you can do to read the results easier.
Jeroenv26
Jeroenv26
Answer 5 years ago
here they are:
Vout:
OFF =
4.30v
ON =
4.68v
ON RET =
4.83v
ON RES =
4.92v
ON ACC = 4.97v
Val
= volts x 1023 / 5 = :
OFF =
880
ON =
958
ON RET =
988
ON RES =
1007
ON ACC = 1017
Average
VAL:
OFF (880-0)
/ 2 + 0 = 440
ON (958-880)
/ 2 + 880 = 919
ON RET
(988-958) / 2 + 958 = 973
ON RES (1007-988) / 2 + 988 = 998
ON ACC (1017
– 1007) / 2 + 1007 = 1012
steveastrouk
steveastrouk
Answer 5 years ago
Check your PMs and ignore my last comment about doing On+RES etc ;-)
steveastrouk
steveastrouk
Answer 5 years ago
When you say "on average", are they fluctuating much ?
steveastrouk
steveastrouk
Answer 5 years ago
Yes, but I don't generally write other people's code for them. Start out with a standard Leonardo keyboard program. Instead of keypresses, read the A/D converter. Measure the output and record that for each switch position, then when a key is pressed, and the A/D output changes, convert the level into the appropriate keypress for the rest of the keyboard program.
You shouldn't have to write much code.
Steve
Kingly2212
Kingly2212
2 years ago
Hey my friend, how’s it going, I was wondering if you’ve got the code for this program. I have the similar problem. And I’d be appreciated if you could help me with this.my E-Mail-Adresse is h.soltani6022@gmail.com
Downunder35m
Downunder35m
5 years ago
I would say post it as an Instructable here instead of asking for advise on project you publish elsewhere ;)
Jeroenv26
Jeroenv26
Answer 5 years ago
I didn't wanted to spam the indestructibles website with an unfinished project. I will post all of my individual steps once finished on this website ;)
