81Views8Replies
Author Options:
I need to be able to see the charge level of a 6v rechargeable battery and want it to be as simple as possible? Answered
-max-
-max-
4 years ago
here you can do it in 3 steps:
1) Get a (good) multimeter / voltmeter
2) Use google to research the battery you are checking
3) check it.
steveastrouk
steveastrouk
Answer 4 years ago
Really doesn't help. Many chemistries keep a very close to constant output voltage over their discharge cycle. SLA is one of the few where a voltage reading will mean anything,
-max-
-max-
Answer 4 years ago
Good point. Of course the best method would be to get a charge/discharge controller for the particular type of battery which can keep track of the joules going in and out, and if a multimeter is used, the battery should be under load, something I couldn't have been bothered to mention before.
iceng
iceng
4 years ago
We have a saying.
Cat_got_your_tongue ?
Downunder35m
Downunder35m
4 years ago
If by charge level you mean the voltage then simply measure it - enough gadgets for that are available from USB testers to fully fedged multimeters.
If you mean how much power is available in terms of Ampere or how long the battery will last under load you need a dedicated battery tester.
iceng
iceng
4 years ago
I have a simple circuit for a liquid sulfur battery, but I think you are wanting to recharge a Lion battery....
steveastrouk
steveastrouk
4 years ago
Depends on the chemistry whether its easy or not. What KIND of battery
