123Views3Replies
Author Options:
I need to create some type of gadget that will automatically loosen and tighten a bolt or screw for me at certain times! Answered
It would need to be attached to a thermostat or timer that will automatically loosen and tighten a bolt or screw when it hits a certain temperature or at a certain time. Any ideas?
robotguy4
robotguy4
11 years ago
A power drill connected to an Arundo?
NobodyInParticular
NobodyInParticular
11 years ago
You might want to back up a step and explain the purpose for which you need this. (Ask it as a separate Question.) There may be a simpler solution.
plumber_bob
plumber_bob
11 years ago
There are several possibilities for this. But the simple concept with the thermostat might be to use some mechanical means, like socket with extension, or rubber tube, to move the screw or bolt,(imagination required), to a D.C. motor. D.C. motors can usually rotate in either direction. The next thing to do would be to wire the motor to the power supply with two relays, in between the motor and power source. When energized, relay #1 would rotate the motor clockwise, when the thermostat reaches the proper point the relay would drop out and stop the motor. Relay #2 would simply be wired opposite of how relay #1 is and hooked to watch the other end of the window. With a timer the same idea, but the relay setup will need to be configured differently but the idea is still the same, relays and motors. Hope this helps.
