If you don't have a proper triangle screwdriver, grind the tip of an old allen wrench into a triangular shape to fit the screws. Use a wrench just slightly larger than the screw slot and try not to overheat the wrench when you are doing the grinding.
You can buy a set of bits for $12 from McMaster-Carr. If you can figure out how to use Google, you can find more from other suppliers. If you can't, you probably shouldn't be messing with electricity.
10 years ago
Answer 10 years ago
Yep. That's what I did except I used an old Phillips screw driver.
Answer 10 years ago
Yeah. Ditto. Also in the related panel:
https://www.instructables.com/id/Screwdriver-with-triangular-head/
10 years ago
