153Views6Replies
Author Options:
I need to run something that is 2 Volts off of my car battery, how can i most efficiently reduce my voltage? Answered
can i make a step down transformer that will reduce my volts from 12 to 2? However it needs to be able to handle about 40 Amps.
steveastrouk
steveastrouk
11 years ago
All 12V Lead acid batteries are 6 sets of 2 V cells in series. With a bit of ingenuity, you could access the individual cells. If you have a brandnew battery, the cell performace will match closely enough that you can parallel connect the cells. Have fun. Remember that a car battery can supply 1000Amps without too much trouble. Metal tools will MELT if you aren't careful.
frollard
frollard
11 years ago
40 amps at 2 volts or 40 amps at 12 volts? Either way, thats quite the load.
thagen
thagen
Answer 11 years ago
40 amps at 2 volts.
frollard
frollard
Answer 11 years ago
what is 2 volts that you need to run? is it possible to operate multiple of them in series?
thagen
thagen
Answer 11 years ago
No, its not. Actually have built a Hydrogen generator. My target voltage is 1.743 V and the more amps the better. so yeah, i just need to find some way to reduce my Volts to around 2 Volts.
frollard
frollard
Answer 11 years ago
I've never heard of a DC-DC converter capable of those currents - Would it not be possible to run your generator in a slightly different configuration (more cathodes and anodes)? Sorry I'm not more help.
