90044Views15Replies
I observed suddenly my car stops while driving, steering wheel becomes hard and speedometer stop working, why?
My car model is Honda CITY 2005 its dolphin type and i don't have any clue about this, please help me!
thank you.
thank you.
Best Answer 5 years ago
Well if the engine stops then power steering stops getting fluid (hard steering) and the gauge cluster is run off the alternator which also dies with the engine.
It looks like alternator problems are semi-common with this car but after awhile it will stop starting because the battery will be completely dead.
The steering and speedo' are symptoms of the engine dying so don't get caught up looking for how to fix them. You need to find the root cause of why the engine dies.
After it dies does it start right up when you turn the key again or does it take a while for it to want to start again? Are there any warning lights on your dash while the car is running?
I'd probably start by carrying a battery tester and then next time it dies immediately testing the battery. If the battery is good when it dies then you can rule out the alternator or anything between the alternator and battery.
Answer 2 years ago
Same problem with my efi car. Plz Help!
My car suddently stops while driving or sometimes after making a stop. when it stops i see no warning lights on the dashboard. engine and the radiator fan stops while headlights and powerwindows still works. warning lights appears on the dash board after 10 to 15 mins or some time after half an hour. the problem appears often appears after driiving 5 to 6 km. My car is also over heating a little. Plz suggest!!!
Answer 5 years ago
After engine dies it start as soon as i turn the key again & I like to mention, few days back before this problem arises, battery was
dead due to rain water filled in FUSE, so my headlight get shorted and hence battery discharged, i charged it and fixed it den suddenly next day morning
i faced this problem. i am not sure about the exact problem so i pulled out few plugs and fuse,pics uploaded here
5 years ago
As in the engine stopped running? Does any of the electronics work? If your getting no power it's likely a battery/alternator issue. Go have it checked by a mechanic. For the most part if the car is running the alternator is supplying the power to run electronics and spark plugs. If the alternator dies on you then the battery will continue to run things till it dies.
I had an issue once where an in line fuse blew. So the alternator wasn't able to power the engine or charge the battery so the car was running only off the battery. Took me a couple of batteries and alternators to figure out it was a wiring issue. Cost me $200 to get it fixed. The wire corroded and broke a couple months later. By that time i knew where the problem was and replaced it myself.
Answer 5 years ago
thanks for reply
i ll do as you suggested
by the way car is in running condition but problem remains as it is, so will go for fuse and den spark plugs, because just 2 days earlier my battery discharged fully cause fuse filled with water and hence headlight power remains ON, so i am considering a fuse problem. lets see
1 year ago
Electronics
1 year ago
I stop by one place for few minutes keeping my car engine on but was stationary at one place suddenly i noticed my car got over heat to 120 while 60 being normal. I immediately turned my engine off. After few minutes when i tried to turn my engine on. My car engine didn't start also i was having problem to turn my stairing wheel also my car brakes got really hard. And on display it was showing sign of battery, oil, and engine. Also i checked my car oil which i just changed last month. Oil was full and ok but it was very hot may be because the car was stationary for long time with engine on. I fear if my car engine got seized or what please reply.
1 year ago
I drive a Toyota Corolla 2009. i notice that my speedometer and odometer stopped reading and break light is on permanently, breaking is hard and steering is also hard.
1 year ago
I have a 2002 Lexus SC430 I was driving on highway 95 and suddenly that car steering wheel started to get hard and the car stalled out looks like it was running hot water was coming out the radiator and it will turn over but dont stay started and the battery keeps deadin
2 years ago
My car is a Toyota Passo Model.
When I'm driving the car it suddenly switched off and no power to speedometer even. however other electric functions are working. like power shutters and lights. After a few minutes back, the speedometer starts back to work and I would be able to start the engine also. This happens me few times. Sometimes it took more than 30 minutes to get power to the car. I checked my battery but the fault still remains.
Please help me to identify the fault.
3 years ago
My car suddenly stops while I'm driving in traffic or I'm on slow motion or I want suddenly turn. Engine still runs, there's light on the dashboard yet it won't move until I turn off the ignition and restart. What do I do? Honda Accord 2004
3 years ago
same thing happened to me today :(
Car is functioning fine.. suddenly the power steering goes out and there is a red light over the battery symbol (Engine is working fine in the whole process). To fix it, I turn off the car and start it again.(It takes to start after this). Car is Honda City 2003.
Please help :(
5 years ago
Your steering becomes hard because the engine has stopped supplying power to the hydraulics.
If the situation happens without warning, then "cures itself" after a while, you are looking at a serious problem with the car's computers (engine management unit etc).
You must get your car to a professional as soon as possible, before the fault occurs while you are cornering at speed, or in an area with other cars & pedestrians.
Answer 5 years ago
If you haven't done this type of auto Reapir your self Just sent it in to a mechanic.
