I think I have a cool idea, will it work?
I would like to see a scientific 'domino's' event. My idea is that you have a series of containers with different chemical combinations, and they all have entry and exit areas. The containers would have a starting spot, whereby a chemical would be added to the current combination, to cause a spurt to leave the exit point, and enter the next container by the entry point, this would cause another reaction, and the chain would continue to the next container. I'm wondering if the reaction could be continued for 20 containers or more. Obviously an explosion in the chain would break the next container, so each reaction would need to be thought out to produce a spurt. What's more the positioning of each container would need to be perfectly planned according to the power of the reaction. For the container's I'm thinking something like a glass watering can, with chambers inside if needed to produce the right reaction or effect. The entry point would be the filling rea, and the spout would be the exit point. I think it's a cool idea, and I would love to know if it could work.
11 years ago
An easier alternative is to set up a physical system that can be triggered by a small chemical event:
- Say you have a bottle that is standing upright but balanced so that it can easily tip over into a depression shaped to fit the fallen bottle.
- In the bottom of the bottle is vinegar.
- Inside the bottle, suspended over the vinegar, is a tissue filled with baking soda.
- A tube runs through the lid of the bottle.
- The tube contains a piston.
So...- You lay the first bottle into its slot.
- Once horizontal, the vinegar soaks though the tissue.
- The baking soda and vinegar react.
- The resulting pressure pushes the piston out of the tube,
- while the depression prevents the bottle from sliding in the opposite direction.
- The piston tips over the next bottle.
If you need further inspiration, try watching some Rube Goldberg competitions and Pitagora Suichi.Answer 11 years ago
I like the idea of involving pistons and glass containers or plastic would show the reactions but glass would require more control of the resulting effect. Thanks for the links too.
Answer 11 years ago
- Set up a long track with a cylindrical groove down the middle.
- Make a tube (similar to what I described above) that becomes a rocket when it is jostled. (Perhaps a pin pokes a hole in a plastic bag of vinegar?)
- Set many of these tubes end-to-end in the track.
So...11 years ago
Energy tends to go downhill. If you had energetic solutions in the containers and used the out put for catalysis you might get it to work. 20 is pushing it a bit though.
L
