1386Views18Replies
Author Options:
I want a cool, easy to edit batch program that has every thing in it, e.g: change user passwords, apps, ect. Answered
who can make me one? please hurry!! P.S it needs to be a batch program, not exe. P.S.S i will put your name in it!!!!
XtreemCoding
XtreemCoding
9 years ago
        I have said program, but i am not going to give as a batch file, i will give as an exe so you cant edit the contents. My program has more than 4,000 lines of coding, and more than 10 programs you can use!
INCLUDES:
Internal Coding info: 4000 lines of coding, advanced *Log in and register* screen, no bugs, USER FRIENDLY!  more than 100 hours of coding time
and code reviewing to make sure there aren't any bugs.
You can get this program, and many more, or possibly join our coding team, at W1gaming.webs.com
Program Features:
*Pc-programs:  computer cleaners, pc info, and many more!
*SECURITY : locks folders and etc...
Misc programs : for fun and etc...
*GAMES:    Includes WORKING TETRIS, FISHING, TICK TAC TOE ,etc
*JOKES:   program! (Racist jokes) includes: Black & Mexican
                                                  - W1gaming....._Xtreem Coding_
Prof. Pickle
Prof. Pickle
Answer 8 years ago
How did 4000 lines of code take you 100 hours? That's only 40 lines per hour of work.
Either your really slow, or I call bullshit.
evilmadcow
evilmadcow
Answer 9 years ago
PLEASE GIVE!!!!!!
Scytheon3
Scytheon3
11 years ago
I have made a program that can do all of these but it needs to be an exe to be secure. So if you message me with your exact requirements then i will make it an send you the exe and the source code
jpwturner
jpwturner
Answer 9 years ago
i would love to see your program
Scytheon3
Scytheon3
Answer 9 years ago
Where should I send it to?
evilmadcow
evilmadcow
Answer 9 years ago
can i have one to, with permission to copy it?(just P.M. it to me.)
Bloblblobl
Bloblblobl
10 years ago
I'm actually working on something like that right now, I might send it to you after I'm finished. It's really awesome (so far...)
Sector 9
Sector 9
10 years ago
 I have a couple scripts and even a program itself that you might like. but i hate to agree with them. you probably need to learn batch and do it youself. ISN'T THAT THE HEART OF INSTRUCTABLES !!??  i cont fit the scripts in so , idk. I could probably put it up as an instructable or an instructables answer page. whatever. so, you want it or not ? its a multi-file thing.
matrix828
matrix828
Answer 10 years ago
hey thanks for the answer!
could you maybe send me the scripts in a PM?
thanks.
TheBatchies
TheBatchies
11 years ago
1. Don't put my name in it, that will make it worse!
2.
@echo off
color 0a
title Operator99
:begin
if not exist password.txt (
goto end
) else (
:Username
cls
set coco= <username.txt
echo Welcome back.
echo.
echo Please enter your username:
set /p username=))
if %username% EQU %coco% (
goto Password
) else (
goto Username
:Password
cls
set co= <password.txt
echo Please enter your password:
set /p password=))
if %password% EQU %co% (
goto OtherPlace
) else (
goto Password
:end
cls
echo Please enter a username:
set /p command=))
if not defined command do goto end
echo %command%>username.txt
:P/W
cls
echo Please enter a password:
set /p commmand=))
if not defined commmand do goto P/W
goto W/P
:W/P
cls
echo Please confirm your password:
set /p variable=))
if not defined variable do goto W/P
if %variable% NEQ %commmand% (
goto P/W
) else (
echo %commmand%>password.txt
:OtherPlace
pause
exit
...I haven't tested it, so don't crucify me!
El Mano
El Mano
11 years ago
A) Perhaps the best all-purpose batch file is Command Prompt. Using it, you can do everything a batch file can do, except maybe use goto (unless you want it to say "Greetings, my Master. We last spoke two hours ago...). If you'll excuse me for suggesting my own program, CMD Commander (which is soon to be updated, for those who care) would be a little more customizable, but you couldn't make you own commands unless you either a) create a specific, new command for every batch command (ex: if %input%==cd_C:\WINDOWS (
cd C:\WINDOWS
, b) use CHOICE, which I'm not very familiar with, or c) have the CMD Commander function be a sub program of the major file
(ex. if %input%==cmdcommander goto Commander
:Commander
cls
etc.)
B) A password is very easy to program in:
@echo off
color 08
set/p password= Your password:
if %password%==*YOUR PASSWORD HERE* (
goto Top
) else (
cls
color 0c
echo You are a failure at life!
pause >nul
exit
:Top
cls
color 0a
echo Greetings, Master. We last spoke two hours ago...
etc.
However, anyone who can edit a batch file (or open it in NotePad, really; I learned batch from a Padlock's folder locker script) can get or change your password. You could either not worry about a password, use one and hope no one fiddles with your program, or compile the program into an .exe, after which the password will be unchangeable.
PKM
PKM
11 years ago
Firstly, your list of requirements is impossible to achieve. You cannot password-protect a batch file so that only you have access to it- someone can easily read out the source code and find the password. You would be better off zipping up the finished batch file in a password-protected zip file, which are much harder (although I'm sure not impossible) to crack.
Secondly, I'm not sure why you want a calculator in a batch file- the Windows calculator does a lot of the simple things you could want from a calculator, a program like GraphCalc will do a wide variety of more difficult analytical stuff, but a batch file calculator is going to be slow and extremely simple because it's such a restrictive language.
Thirdly, you don't specify what you want from these "quizzes, guessing games" and so on. You also specify that you want a "simpler but better" program than tat creator- I checked out the source code to TAT, it's pretty simple if you know batch (but a bit of a mess because batch relies on goto statements rather than proper program structure).
Lastly, you say P.S.S i will put your name in it!!!!. This makes me a little curious- what are you planning to do with this batch file that you are farming out the actual creation of?
Rather than give a lengthy, demanding and (in my opinion) impossible to achieve list of requirements, why not actually learn to write batch and write your own with everything you want in it? You say I already know lots about batches, this will be a great exercise and way to learn more. You might even learn enough about why batch is a horrible programming language to inspire you to learn a real one :)
fwjs28
fwjs28
12 years ago
check out tat creator
matrix828
matrix828
Answer 12 years ago
i have!! lol but i want to have a simpler one!! but better!! (if that is possable lol)
fwjs28
fwjs28
Answer 12 years ago
hrmm...what do you mean by simpler?
