303Views2Replies
I want to bind together two pieces of hard candy
I need to get 2 semi-circle shape hard candy pieces and bind them together.
Is a molten sugar glue gun work for this?
Is it fairly sage to use?
Safe to consume?
I need to do this for mass scale...
Not at the beginning though....
4 years ago
What candy is it?
Just melt them and hold them together
4 years ago
wetting the surface and pressing together will work.
Reply 4 years ago
thanks very much for your reply;
but will it hold off strong enough?
I need the 2 pieces to become one piece of candy and to be used for purposes like a lollipop without breaking.
You see my problem is that I cant get a candy cylinder shape with hole in middle done. So, but I can make 2 semi-circles and then hopefully bind them together..
I'm not sure whether getting them wet will bind them together strong enough...
Reply 4 years ago
If you want to make a full circle then use a teflon rod in the middle.
Once the candy is cool you can push the rod out.
Reply 4 years ago
Or put the lollipop stick straight in the molten candy and let it set?
