1020Views8Replies
Author Options:
I want to build a power supply input 12 or 24 VAC output12VDC? Answered
iceng
iceng
Best Answer 9 years ago
Here you go INPUT 24VAC and OUTPUT 12 VDC..
Just ignore the 5 VDC section.  .  .  . A
Basem Salib
Basem Salib
Answer 9 years ago
thanx for this but i see it's very complex
if i make 12 VAC input and 12VDC output will be the same desing?
iceng
iceng
Answer 9 years ago
You Scare easy :-)
12VAC makes the reg ripple much worse .
I cut the parts that made a Cadillac, now you have a Ford.
A
iceng
iceng
9 years ago
Reg = Regulator
Accepts up to 35 volts on the input pin with respect to ground.
and regulates 12 volts on the output pin with respect to ground.
Basem Salib
Basem Salib
Answer 9 years ago
ok many thanks Mr.Iceng i'm already working to do it
Basem Salib
Basem Salib
Answer 9 years ago
from a trasfomers and four diods ...i don't if i have to use anther components?
lemonie
lemonie
Answer 9 years ago
Just use the four diodes like iceng has in that diagram.
L
Re-design
Re-design
9 years ago
Google "12 v power supply" and take your pick.
