5224Views3Replies
Author Options:
I want to buy a 40W solarpanel how can I calculate how "heavy " the controller and the inverter should be? Answered
The man in the shop told me it would be wise to buy these things too. If I want to use it continiously he advised a battery. How heavy should this be and how can I calculate it for a panel of 80 Watt Thanks in advance
q280298618
q280298618
11 years ago
solar panel supplier from china
power range:3watt tp 290watt mono or poly  Passed: CE,IEC,TUV  packing wooden pallet  MOQ: 20pcs
www.china-solar.cn
wendywong@yahoo.cn
TEL:86 13401273120
frollard
frollard
11 years ago
*all numbers assume 100% efficiency, this is not the case - expect some losses*
Assuming you get 10 hours of 40 watts every day, thats 400 watt-hours per day. (multiply them). Thats 400 watts, for 1 hour, or 1 watt for 400 hours, however you wish to use it. using a 1000 watt panel for 10 hours would be 10,000 watt-hours, or 10kWh (you're used to seeing that unit on your electric bill)
400 watt hours in a 12volt battery is (watts are volts*amps) 400w/12v = 33.3 Amp Hours @ 12V. Batteries come rated in amp-hours. You need as many batteries as it takes to reasonably hold as much charge as you'd reasonably store up in a day or two. Adding more storage is okay if you don't use the power often.
400 watt-hours is a high-end computer running for about 2 hours.
Eg2, 80 watts * 10 hours = 800 Wh
at 12v = 66.6amp hours per day (again, see it as 66 amps, 12volts for 1 hour, or 1 amp, 12 volts for 66 hours)
Inverters are rated in Watts - The inverter can be sized to whatever load you'll put on the system. To charge phones and a laptop, you'd use ~100 watts, and could use the system for 800/100 = 8 hours per day.
To use a 1500 watt space heater, you'd get 800Wh/1500 = 0.53 hour=32 minutes, per day.
Hope this helps!
lemonie
lemonie
11 years ago
Do you know what voltage the panels output?
The battery will give you a constant steady supply, with the solar-panel keeping it charged.
You need an inverter if you want to run mains AC devices.
Not sure what you mean by a controller though?
L
