172Views3Replies
Author Options:
I want to capture photograph from two cameras simultaneously...so how to create a manual twin camera click triger??? Answered
In short two cameras should capture at same moment. from only one switch.....
{Its used to capture 3D photographs known as analglyph imageg}
Please explain completely.....
Vyger
Vyger
9 years ago
There is a crude but very effective way. What you do is set both cameras to have an open shutter (used to be called B for bulb), set everything up the way you want it, open the cameras shutters and flash it manually with a flash unit. Since you have only one light source both will record at the same instant. This is controlling through the light rather than the shutter,
frollard
frollard
9 years ago
You need some method to actuate the shutter remotely.
Ideally, both cameras are identical, and have an input for remote shutter. Then its simply a matter of clamping them down, aiming them, and hooking the shutter releases together. Safest bet would be to use a double pole switch so each camera is actuated at the same time on a different circuit.
If you can't access a camera that has a dedicated shutter release, there is a firmware you can get called CHDK (canon hack development kit) that works on many canon point and shoots to allow usb voltage detect shutter release. Hook up a switch to 5v and plug into each camera's usb port - usb will trigger the picture.
Even simpler (yet more complex mechanically) is physically hitting both switches at the same time. There are cable releases to do this for many cameras - and an instructable on how to build one.
Post processing: Various programs can take in both pictures and make an analglyph.
AndyGadget
AndyGadget
9 years ago
A lot depends on what make / model of cameras you're using and how they would normally be remotely triggered. Check the manual.
There's a lot of camera remote Instructables on here - Have a plough through and see which would be applicable to your camera, then modify to suit.  Modifying to double up the output should be quite easy in most cases.
