257Views4Replies
I want to make a full h-bridge for a 24 volt 60 amp load motor from all n channel mosfet ?
if some one knows how to make pls help me and also i dont want any microcontroller and mosfet gate driver ic in this circuit
5 years ago
You don't need an H-bridge and use any single NorP FET for 24 VDC.
5 years ago
Wow that is 1440 watts.
The biggest ones I have are 300 watts at about $100.oo each it would take 20 of them to drive your motor in an H bridge.
It is a simple circuit with the mosfets stacked not much different than the inverter circuit in this Instructable.
https://www.instructables.com/id/Modified-Sine-Wave-Signal-Generator/
Just instead of converting DC to AC you would be using it to drive a motor.
The thing is the power parts try this supplier
http://ca.mouser.com/Electronic-Components/
5 years ago
Well, Google is your friend....
PWM signla generation using a 555 timer.
H-Bridge configurations and circuit options.
And you might be able to use a gate driver in the form of a toroid transformer - again Google is your friend.
Answer 5 years ago
i wouldn't dream of not using a driver, personally. Pushing the required gate current into the pin is not trivial. Get it wrong, your main fets over
