OK.
get 4 lengths of wood. about 2cm thick, 20cm wide and 1 meter long.
on each length, measure about 10cm from each end and draw a storage line down at this point.
now the clever bit.
measure 2cm from these lines and then draw a line to half way down each length. you should now cut the section of wood you have just enclosed out with a hand saw.
you will now have four peaces of wood with a 10cm strip removed 10cm from each end.
slot the wood sections together and you have a no drill earthbox.
was going to post an image but I can't get my scanner to work.
11 years ago
OK. get 4 lengths of wood. about 2cm thick, 20cm wide and 1 meter long. on each length, measure about 10cm from each end and draw a storage line down at this point. now the clever bit. measure 2cm from these lines and then draw a line to half way down each length. you should now cut the section of wood you have just enclosed out with a hand saw. you will now have four peaces of wood with a 10cm strip removed 10cm from each end. slot the wood sections together and you have a no drill earthbox. was going to post an image but I can't get my scanner to work.
Answer 11 years ago
got scaner working
11 years ago
You could make a hanging planter from a plastic bottle- search this site.
11 years ago
simple get a plastic tote and using a knife stab some drainage holes!
