212Views3Replies
I want to make and old school dial water meter using arduino and flow meter?
i need help making a old school dial meter like the ones used in electricity or auto richshaws.
http://static.splashnology.com/articles/Examples_of_Skeuomorphism_in_Graphic_Design/Rickshaw_Meter_app_by_ranganath_krishnamani.png
i want to flow water through a flowmeter and record data from arduino. i also want this arduino to control dial meter and show the appropriate numbers depending on the litres flown. i do not have any knowledge of coding , however im alright to prepare the hardware and solder etc! if i has a set of instructions
4 years ago
1. The meter will be hard to make unless you have very good workshop skills
2. You learn programming skills by starting with very small tasks, like flashing an LED, then turning it on in response to an input, then turning it on conditionally.
As you become more familiar you will understand how to count pulses and send outputs to the counter to operate that.
3. No one here is likely to create the program for you - the learning experience will be good.
Answer 4 years ago
Thank you for your reply and sending this to me. however i have tried using it a little and im just not cut out to make a program. luckily in india labour is cheap and ill get a team to make this. however i would like to know where i should start
Answer 4 years ago
The 2 videos show you how the meter might work.
As for the programming - If your team are up to it they will know how.
