2046Views28Replies
I want to make power supply from 220 V AC to 300 V DC variable/adjustable?
I want to make power supply from 220 V AC to 300 V DC variable/adjustable? someone please help me or give me a link of workable circuit?
7 years ago
There are multiple ways to accomplish this. One way is to use a simple variac (google it) these are simply adjustable transformers, and will allow you to adjust AC mains voltage to anything between 0V to whatever the max output voltage of the variac is. Usually about 300V. However, variacs tend to be a bit pricy, and likely overkill. What is the purpose of this variable supply?
Answer 7 years ago
A Variac is NOT MAINS ISOLATED, and therefore very dangerous unless appropriate precautions are taken.
Answer 7 years ago
Then just connect its output to a isolation transformer. besides, if proper precautions (common sense) are taken it will be fine.
Answer 7 years ago
Then make sure you mention it, when you tell people to use things like variacs.
Answer 7 years ago
Why does main isolation matter if it is set on a lower voltage? besides, dealing with anything over 50 volts is dangerous (unless it is current limited).
Answer 7 years ago
What's the voltage ? Referred to ground ? And no, anything that can drive more than 20mA through your heart is potentially fatal - less if you're old/young/ill. Voltage has nothing to do with it, in the sense of the level of it being safe or not. The 20,000V shock I receive in winter, walking over the carpet is not fatal.
Answer 7 years ago
voltage dictates how much current will flow (Ohms law). a 12 lead car battery can pish out thousands of amps, but they dont kill because the voltage is not high enough to cause a significant current through the body. I also stated "current limited". I mean ~10 mA current limited. I would know.because I mess around a lot with high voltage.
Answer 7 years ago
WHAT??? I think someone should step away from the keyboard.
Answer 7 years ago
Less than 9V has been know to kill, less than 10mA has been known to kill - that's why earth leakage limits on medical equipment are 1/10th of those for other types.
RESISTANCE controls current flow. (Ohms Law)
A car battery can't push ANY current into an infinite resistance.
You may mess around a lot with high voltage, you appear to know dangerously little about what it is and when it can cause damage.
Answer 7 years ago
9 volts directly across the heart will probably cause enough current to flow. yes, I know. Ohms law is a basic equation that mathematically demonstrates how current, voltage, and resistance are related.
Answer 7 years ago
Now imagine that 9V superimposed on 110.
Answer 7 years ago
Why wouldn't you connect a isolation transformer to the variac input ?
Answer 7 years ago
I never said I wouldn't connect it?
Answer 7 years ago
I was asking you, what about putting the isolation transformer on the mains side
of the variac instead of the output ?
" Why wouldn't you connect a isolation transformer to the variac input ? "
7 years ago
FYP people, "Final Year Project", please answer appropriately.....
Answer 7 years ago
Being appropriate ;-)
I was only trying to determine if this young man has enough knowledge to avoid
being hurt by the very energy he wants our help to control.
He does not appear to have an understanding of isolation transformer size relating to current.
Let alone the concept of a switcher.
It is almost as if a circuit is going to provide the answers to everything.
May be we should simply show a TR unit with a variac.
A
7 years ago
300V adjustable from what to what (and why ? ) And what current.
Answer 7 years ago
220 V AC to 300 V DC and current may be 1 A or any other value, 300 V is important
Answer 7 years ago
Yes we get that. You want to convert 220VAC to a max of 300VDC. But what adjustment range do you want for the DC side. 0V-300V, 5V-300V,3V-300V, ect. Also why do you need an adjustable supply that can offer up to 300VDC but only up to 1A?
Answer 7 years ago
0 - 300 V, for my FYP
Answer 7 years ago
FYP = five year plan ?
Answer 7 years ago
300V regulated, 300W PSU.
Adjustable from what to what ?
Answer 7 years ago
0 - 300 V.
Answer 7 years ago
How much electronics experience, and working at high voltage do you have.
Do you need current limiting at 1A ?
Answer 7 years ago
I m a student and want this supply for my FYP, current may be less than 1 A but 300 V is important may be 1.2 - 300 V.
Answer 7 years ago
Ah, the idea of "FYP" is that its YOUR work. We'll assist, we won't DO your project for you.
This would make a great switch mode PSU project, but you could just about do it in a linear one, though in some conditions, you will have huge power dissipation in the pass-bank.
7 years ago
Most PLC work on the power supply 24 VDC or 220 VAC.
7 years ago
You know.... Oh darn you just joined and have no bio....
To let me know, if you know, what you are doing...
Please tell me the multiply factor when converting AC to DC through a DC bridge rectifier ?
A
