162Views3Replies
Author Options:
I want to run 20-12v leds, witch allready have resistors, what circuit am i best using and what power will i need?ty? Answered
Basicly i want to run 20 5mm uv leds, they allready have the resistors prewired, and state a 12v power source is needed but i wanty to run all 20, what circuit would be best and what kind of power suply and voltage any help would be great chhers
Tags:ledhelp
frollard
frollard
10 years ago
Both steve and trub are correct == Each led series strand needs its own resistor. In this case it is a strand of 1, with a big resistor to burn off about 9 of the 12 volts. They can be wired up right now all in parallel + to +, - to -. directly to 12 volts.
The Solution trub is saying is to remove the individual leds, and run 3 or 4 of them in series.  Then you would only need a small resistor to burn off the last tiny bit of voltage to protect the strand.  It's more work.
Both will work --  I don't like the pre-resistor'd leds, as they remove a lot of the options.
trubshac
trubshac
10 years ago
Can you remove the resistors? If so, you put a number of them in series with a single (different value) resistor.
steveastrouk
steveastrouk
10 years ago
You run them all in parallel, off a 12V powersupply. Steve
