1432Views2Replies
I would like to purchase automatic button pusher machine with on the hour function; how much would it cost?
The b=automatic button pusher machine should be able to press a button every hour on the hour. It should be easy to set up.
9 years ago
Homer solution...
9 years ago
depends on EXACTLY what it does
What is this button?
Can it be automated otherwise/with software? (is it a computer key that can be faked?)
Does this button require a simple 'circuit connection'
--could the button be shorted with a relay
--is it normally open or normally closed
Bare minimum, I could make something oscillate roughly every hour for about a dollar. The relay it would switch would be a few dollars
It might need a power supply, another few dollars.
if it has a microcontroller for more control, another few dollars.
