1024Views5Replies
Author Options:
IR (infrared) tripwire (arduino)? Answered
How can i build an infrared tripwire for my arduino bored i have a IR photo transistor and a IR led,
What i want to do with this is control a relay which turns my light on when i enter the room and off when i exit.
Thanks
iknowvations
iknowvations
Best Answer 8 years ago
To make your project, you will need two IR leds & two photo transistors. This is needed as the system has to decide the direction of your movement. That is to say you have entered or made an exit.
You have to set the two leds & two photo transistors parallel in such a way that when you enter one line will be interrupted first & then the other. This will be reverse when you make exit. Monitor this two lines & make the relay on & off accordingly.
I hope this will make your project work. If you need more info just let me know.
iknowvations
iknowvations
8 years ago
Thanks for marking as best answer.
Jayefuu
Jayefuu
8 years ago
The problem with that is if someone else enters the room after you you're both left sitting in the dark.... :D
You could use 1 laser like iproberry suggested. Or a pair so you can tell whether someone's entering or exiting. It could keep track so that it turns off with the last person to enter.
OR you could put a non-touch switch in place of your regular light switch that requires you to put a shoulder or something against it to turn it on. Like they use for the touchless bathroom taps.
lemonie
lemonie
8 years ago
What's the problem with using the light-switch and a finger? Hands full of things?
L
