466Views33Replies
Author Options:
I'd like ideas for a domestic ejection-seat, any about? Answered
For artistic purposes, "we" are interested in making an ejection mechanism to remove a person from a household arm chair.
I've thought of>
Springs
Gas-rams
Sealed gas-struts (car tailgate)
My main sticking points are: pushing the thing down if not using active gas-power, and the hassle of gas valves etc.
All suggestions welcome
noahh
Best Answer 8 years ago
Springs and a pivot seem like the easiest way to go.
lemonienoahh
Answer 8 years ago
Do you have something you could put in a diagram/picture?
L
noahhlemonie
Answer 8 years ago
Sure, here you go. The idea is that the springs will be in a compressed state and held in place by some sort of catch. When triggered, the springs would expand to their normal state, and the chair would swing forward on its pivot. It would be a very violent forward-jerking motion as opposed to the "up and out" motion that I assume you're thinking of, though. I'm not sure if any of it would work, but it's just an idea.
-Noahh
lemonienoahh
Answer 8 years ago
I'm judging this to be the best answer given. The problem I have with this type of mechanism is the force needed to compress the springs, still I suppose two people could set the thing.
Thanks
L
icengnoahh
Answer 8 years ago
springs must be able to lift your wight plus chair plus 20 %.
someone will have to help you compress them
A
noahhiceng
Answer 8 years ago
That's true, but Lemonie said that it's not necessarily going to be used with anyone in it, so the springs wouldn't have to be able to lift a human's weight.
icengnoahh
Answer 8 years ago
Also True.... I thought you might ketch me there.
Lemonie is very proper centric.
But to be realistic in the sense of a MythBuster
You got to get Dangerous :-)
A
icengnoahh
Answer 8 years ago
How heavy are you ?
In my case it will take pneumatics :-ß
iceng
8 years ago
Let me present, this electrically driven chair to launch crock man. A
lemonieiceng
Answer 8 years ago
Strange, if it could go a bit quicker at it...
L
icenglemonie
Answer 8 years ago
Sure I can double the motor speed and cut frames from the film.
Work for you ? A
lemonieiceng
Answer 8 years ago
"Real chair with fast-eject" is in my mind.
L
icenglemonie
Answer 8 years ago
I know.... but couldn't let this self rising chair be, and yea it was slow and mellow.
You realize... aww Steve already said it.
Do you watch the Myth Busters ?
They did a rocket chair, four rockets, one per chair leg.
The chair dummy got flipped and killed.
There was no balancing four chemical rates of burn !
A
lemonieiceng
Answer 8 years ago
Hm, I missed that
L
gruffalo child
8 years ago
How about a chair with an iron under the seat that turns on when someone seats on it? Not exactly what you wanted, but more realistic and rather artistic.
steveastrouk
8 years ago
I'd be really careful putting enough force on someone to eject them, because you are going to hurt them badly if you aren't very careful.
lemoniesteveastrouk
Answer 8 years ago
The motivation is to make it, rather than use it.
L
rickharrislemonie
Answer 8 years ago
If your not going to actually use it then a BIG SPRING Wile E Coyote style
rickharris
8 years ago
It would be easier to drop them onto the floor rather than eject. Less force required.
lemonierickharris
Answer 8 years ago
That'd be a rocking-chair type tip, and that had been thought of - how might the tip be driven without tipping the whole chair?
L
rickharrislemonie
Answer 8 years ago
I was actually thinking of a drop seat - Ducking stool style.
knexinventer
8 years ago
put a airbag with a triggure under the cussion then when the unsuspecting victim sits in thechair that person gets blown away
lemonieknexinventer
Answer 8 years ago
I had thought of that (more like seatbelt pre-tensioners) but these things are hazardous and I don't know whether they are left in at car salvage yards.
Also, they only work once.
Thanks for the suggestion though.
L
orksecurityknexinventer
Answer 8 years ago
"For artistic purposes", I suspect that's as good an answer as you're going to get.
For practical purposes, I suspect there is no good answer.
JamesRPatrickknexinventer
Answer 8 years ago
I think this would be the easiest, most efficient route to take. They're pretty cheap, too($5-$20).
Quercus austrina
8 years ago
For artistic purposes, I'd uses compressed air to move the chair at a 45 degree angle to the base with a force of around 40-50 lbs more than the chair. Use slides/rails to provide positive stops and to keep the chair and base connected. Even if it doesn't "eject" a person, the sound will make them move.
Qa
jimc4567
8 years ago
Do a search on motorized lift chairs. Here's one from a medical supply company. They are not cheap.
http://www.usmedicalsupplies.com/Lift-Chairs.htm?utm_source=business&utm_medium=cpc&utm_content=default&utm_campaign=liftchairs
rickharris
8 years ago
It's going to cost you. Do you really want to spend just for a whim?
lemonierickharris
Answer 8 years ago
For artistic purposes, there's an idea behind it (a joke if you prefer).
L
karlpinturrlemonie
Answer 8 years ago
Hmm, think I'd prefer a joke...
But...
My mum uses a riser(?) chair that simply has a lever - in the locked position, it's a normal chair, but dis-engage it, and the springs inside will push you and the seat up.
The lever is then used to assist in sitting back down - which also helps compress the springs before latching the lever back in place.
I don't know about the internal construction, but there may be a possibility of swapping the springs for stronger ones, though that would make the lever harder to operate (even if you lengthened it, probably).
But for artistic purposes the riser(?) chair may be too much of an obvious cliche.
rickharrislemonie
Answer 8 years ago
My parents had an arm chair that was sprung to assist standing from the sitting position. When empty it reset to horizontal.
Vyger
8 years ago
Simply asking often works pretty good.
Non forceful or non powered things that would work could be really bad smells and sounds that would cause a person to quickly move.
There are a lot of assist chairs on the market, they all use motors. Motors are slow enough so any kind of injury is often avoided. A chair that simply "stands up" leaving no place to sit on it would be pretty interesting. A slow motion eviction. Also a slow motion set of spikes coming up through the cushion would get attention, eventually. That would be fun to do with a dog.
If you are talking about ejection as in thrown out, its a bad idea inside a house. With low ceilings any kind of abrupt powered device is likely to throw someone into the ceiling and could cause pretty serious injury including broken necks and even death. Hmmmm a new and interesting form of execution? "Have seat, the executioner will be with you shortly"
Mythbusters did a segment on car ejection seats. They used compresed air and it worked better than they thought it would. It launched Buster quite a distance. (Buster is a test dummy)
lemonieVyger
Answer 8 years ago
For artistic purposes, a proper throw-out/off is what's required. Perhaps only for demonstration purposes without the full lifting force.
L
