460Views6Replies
Author Options:
If I connect an AC fan motor to an engine of some type, will it create AC current? Answered
Or am I completely wrong in thinking that a motor can be a generator if you apply force to it instead of applying electricity?
squirt8500
squirt8500
Best Answer 11 years ago
Most types of AC motors are induction motors, that means there are no magnets, so you can not generate electricity with induction motors.
You are right that some motors can generate electricity with applied force they are permanent magnet and usually DC motors.
sockless
sockless
10 years ago
You could rip the alternator off a car.
For Better Or Worse
For Better Or Worse
11 years ago
squirt8500's answers technically speaking is incorrect regarding the ac induction motor, but DC PM motors are the best in your case because it is easy.
One tip though, if you are planning an making a wind turbine, than not any dc motor will do. Look for motors with a low rpm speed and a high volt/amp input. those motors will produce sizable amounts of power at low rpm.
steveastrouk
steveastrouk
11 years ago
squirt is actually wrong. By adding a capacitor, an induction motor run at over its base speed will generate.
lemonie
lemonie
Answer 11 years ago
I agree with you there, but I suppose it saved someone the hassle of trying?
L
lemonie
lemonie
11 years ago
Any general-purpose motor can be made into a generator and vice-versa. But you need to be very specific on the motor if you want advice as to how.
L
