2659Views8Replies
Author Options:
If a 12v car battery is down to 6v can you still charge it? Answered
Tags:Battery
rickharris
rickharris
10 years ago
Mmmm The wisdom says anything less than 10.5 is seriously damaging and needs special efforts to recharge.
A desulphator circuit (search for it) may help.
steveastrouk
steveastrouk
Answer 10 years ago
Yes, its very deeply discharged. If its happened recently, it may live.
Re-design
Re-design
Answer 10 years ago
But it will probably only live until cold weather. I've found that once discharged this low mine usually fail the first winter.
steveastrouk
steveastrouk
Answer 10 years ago
Yes, that's true.
caarntedd
caarntedd
Answer 10 years ago
Cold will kill it.
NachoMahma
NachoMahma
10 years ago
.  It's worth a try, but don't have high expectations.
.  It will probably charge (as has been mentioned, you may need a good charger to handle it), but it quite likely will not be as good a battery as it was before - it probably won't hold a charge as long and probably will not put out as much current under full-load.
.  If you want to know why, Google "battery sulfation".
.  Good luck.
lemonie
lemonie
10 years ago
If it looks sick like it might need to be retired, why not just try charging it?
But if you've got cell-failures, you can't fix 'em. It gets h0rrible in there,full of sludge...
L
steveastrouk
steveastrouk
10 years ago
Yes....but you may find it blows the fuses on your charger. You need to charge it, or it will die from sulphation.
Steve
