9454Views9Replies
Author Options:
If you place a 1 ohm resistor across a 12 volt car battery, how much power will it dissipate? Answered
This is one of the exercise from the book, "The Art of Electronics." They do not give answers and i wanted to know if i did it right. I got the answer of 1.44 watts, but i am not sure if this is correct.
rickharris
rickharris
Best Answer 5 years ago
Using ohms law:
I=V/R
then 12/1=12 amps.
Watts =V * A
so 12 * 12 = 144 watts.
We would expect a 1 ohm resistor to draw a LOT of amps and so dissipate a lot of power.
Your answer works for a 100 ohm resistor though
12/100 = 0.12 amps
0.12 X 12 = 1.44 watts.
Yonatan24
Yonatan24
Answer 5 years ago
That's only partially correct because most resisitors would catch fire after less than 5 seconds...
Unless you have a 150 Watt resistor, Which I don't know, but I'm guessing they aren't sold as 1ohm
cooldude01
cooldude01
Answer 5 years ago
Thanks. I had got both answers but i didn't think it was 144 watts because it was so high. Alright thanks lets me know i am on the right track.
-max-
-max-
Answer 5 years ago
Nooo! A 1 ohm resistor is practically a short circuit! It will only drop a volt for every amp of current flowing through it! You can check out my videos about ohms law and watts law and series/parallel circuits on youtube, under the channel Power Max if you're intrested.
rickharris
rickharris
Answer 5 years ago
It's often useful to take circuits to mental extremes. for example we all know that a total short circuit would draw as much current as the power source can supply. 1 Ohm is not far from that short circuit so the answer is going to be high.
cginella25
cginella25
4 weeks ago
A car battery has 500 amps and up. Where would your 12 volts go if you loose a volt for every amp
cginella25
cginella25
4 weeks ago
I use a 10 ohm resistors on a 9 volt battery as an ignitor for rocketry. Sometimes numbers are just numbers
Frankie Bleddyn
Frankie Bleddyn
2 months ago
You are no doubt way past all this, but OHMITE makes great load resistors that will handle the kind of power you are talking about. 144 watts, but you know that already.
ChetH2
ChetH2
2 years ago
What resistor would I need to drop 6 volts to 4.5 volts?
