253Views5Replies
Author Options:
If you used a AC/DC, series wound, 115V, 1.2 fla, 1/15hp, 5000rpm, motor as a generator what Voltage would you generate? Answered
If I spun the shatt of this motor at 5000rpm what should I expect to generate in voltage and Max watts.
one_fake_user
one_fake_user
10 years ago
If it is an induction motor you will get about 1 or 2 volts. They are an efficient motor but are not an efficient generator. If it is DC and has permanent magnets then you will get about 115V.
The Ideanator
The Ideanator
10 years ago
You could always test it with a multimeter or oscilloscope.
steveastrouk
steveastrouk
10 years ago
Around 115V, but only if it had a load attached. MAximum watts would be close to 1/15 Hp ~50W
rpshomeservices
rpshomeservices
Answer 10 years ago
Could I control the output voltage from the generator by simply using a motor variable speed controller rate for the motor?
steveastrouk
steveastrouk
Answer 10 years ago
Hmm, not sure, I am not a generator specialist. My immediate thought is you can do it just by changing the motor speed. The classic way, in a separately excited machine (where the field current is controlled by another power source), is to change the field current.
Steve
